Stepped header 1 3/4 to 1 7/8 on an AFR 205, 224/228 car?
Hey guys, i haven't bought my headers yet and Edelbrock came out with some stepped Stainless headers for $619 and a stainless ypipe for 169. I have AFR heads 205cc and was gonna get the AFR 224/228 cam. Would i lose power with these headers? Thanks!
Mike
Mike
Well i did use the search and most of the threads are 1 7/8ths vs a 1 3/4 header. Not to much info on the stepped ones. thanks for the opinions, keep em coming!
I found this out:
hope it helps these headers are making the extra power that we all want
Originally Posted by BAIN
I do not agree that stock cubed motors will not benifit from larger headers than 1 3/4".
On my stock 346 w/T-rex and stock 241 heads my car picked up a good amount from Hooker 1 3/4 LT's 3" X-pipe duals w/4x9 3" Magnaflows dumped at the axles changing to Edelbrock 1 3/4 - 1 7/8 slip on colectors and 4x9 3" Magnaflows off the header. I haven't put it on the dyno to see the power difference, but it's deffinately there according to the track times. There are no other changes other than the exhaust in the following times and I have corrected them to 0 DA to factor out the weather....
5/12/06 +728 DA
60'___1.53
1/8___7.054@96.98
Corrected to 0 DA = 7.0@97.72mph
6/16/06 +3358 DA
60'____1.52
1/6____7.085@97.68
Corrected to 0 DA = 6.8@101.63mph
So for me there was a differnce of 2 tenths and 3.9 mph!!!!!!
5/12/06 +728 DA
60'___1.53
1/8___7.054@96.98
6/16/06 +3358 DA
60'____1.52
1/6____7.085@97.68
The step creates a venturi in the primary which helps the exhaust move through the tubes faster, therefore creating more flow and less backpressure. apples to apples a stepped header will usually be better for LS1's.
I helped a friend install the edelbrocks (coated) and was more than impressed by the fit and finish, also he picked up about 25hp with tubes and a tune. Not bad for a 99.
Josh
Josh
Mike
Mike
You dont need to contact a the guy that makes the heads....contact a ls1 shop that builds street and race motors every week and have 1000x times the experience with different combos and parts on a variety of applications.
Jegs is the only place i found them - $710
350-65701
Victor Series Drag Racing Headers
1998-02 Camaro/Firebird/Trans-Am LS-1
1-3/4'' Stepped to 1-7/8'' Primaries
3-1/2'' Collectors
T-304 Stainless Steel
350-65701
3-1/2'' Collectors
There's a soponsor on here selling them cheap.
the thread
https://ls1tech.com/forums/showthrea...lbrock+headers
the thread
