At what point does the stock MAF become a restriction?
High on diesel fumes
Mods in sig, Radix @ 9 psi, 6.0L LQ9.
I've done some searching, and seen a lot of threads stating that the stock MAF is good for awhile, but I'm wondering around what power levels the stock MAF actually becomes a restriction in the intake tubing. I'm contemplating going with the LPE 100mm but I don't want to if it's not going to get me anything.
When it limits your ability to control the AFR consistently, it's a restriction. In other words, it'll become a tuning restriction before it becomes a substantial physical restriction. You could try switching to a larger MAF (ie Z06 MAF) if you feel it's really a bottle neck. But, I don't think that's the issue unless you're running no filter and a 90/90 setup making 600+hp.
I am running a 90mm TB, goal is 12's and 500rwhp, and I'll probably be throwing a 50-75 wet shot at it as well sometime in the near future.
Tuning I'm not worried about, I know the tuning limits of the MAF, just wondering about actual physical airflow restriction.
Originally Posted by 02TransAm/Batmobile
damn, i hope i never run into your truck!! impressive! . . .
Ok, that's two people I've heard 600 from, so I think I'll be fine with the stocker. Thanks everyone!
I would ask 300bhpton, he knows just about all there is to know, especially when it comes to restrictions. I expect him to chime in at any minute. I don't see the MAF being a restriction for ya.
-Mike
-Mike
Originally Posted by Cop Car
just get a SD tune and not worry about it.
I never had a problem with the MAF, but i switched to an SD tune mainly over constant problems with my O2's. Most good tuners will tell to stick with the stock MAF. I believe the MAF is one of the last restrictions to worry about in your intake.
I'm having problems with my O2's also, hoping they go away when I swap headers this week. I'd like to go back to closed loop if possible, but am currently running OL 2bar MAF, and I think this will be fine too if I have to stay OL.
Contrary to popular belief, upgrading to a larger MAF has two benefits: (1) better throttle response, and (2) ability to support more airflow.
Just like the Throttle body. It's only 75 mm, same as MAF. If you port the throttle body, you get a larger opening, which in turn offers the two advantages I listed above. It just makes sense that the same applies to the MAF, flow wise. Just don't say that too loud around here.
