Fuel line size?
Old 11-01-2006, 11:25 AM
longboard's Avatar
Default Fuel line size?
I'm installing an LS1 in a 61 Impala. I know I need to run a return fuel line. My question is, what diameter should the inlet line and return line be? Also, I plan to install a sumerged fuel pump in the gas tank, what fuel pump presure should the fuel pump be?
I'm kinda hoping to use a pre-bent replacement fuel line for both the inlet and return, but I think it's only 3/8"
Old 11-01-2006, 04:40 PM
Has Unresolved Sales In Feedback/12 second club
notatruews6's Avatar
3/8" will be pleanty big, i would recommend using the 99+ Ls1 Fuel rail that way you dont have to run a return line. The fuel pressure is regulated on the fuel rail.
Old 11-01-2006, 08:15 PM
Shallow Bay's Avatar
https://ls1tech.com/forums/fueling-injection-8/
Old 11-01-2006, 08:37 PM
longboard's Avatar
Thanks guys. I should have noticed the other forum. rookie error
Quick Reply: Fuel line size?
