LS6 into 98 a4
LS6 into 98 a4
Hi
Any one know what I will need to do to put the GM LS6 long block crate motor that comes with the Camaro oil pan into my 98 A4. Can I swap over accessories, wiring, manifolds, etc? Will it work with the 98 computer?
Thanks JA.
Thanks JA.
Originally Posted by BrandonDrecksage
why are you swapping long blocks? All you need is the heads, ls6 intake and ls6 cam kit..and your set for about 5-5.5k less than what the crate motor cost.
Not that much lesss. I priced that route out with a local spped shop. There is not alot of support in my area. The parts were well over 3k before labor. Also, a crate motor means new stuff in the bottom. You do have a valid point though.
JA
Originally Posted by JGA
Hi
JA
JA
Originally Posted by sdbrown84
If you are swapping blocks why not go LS2 or just go all the way with a 408?
Hi
Can I get an LS2 to work with my 98 computer? I also have a government scan and sniffer test to deal with.
Thanks JA
http://www.racetronix.com/RX-LS2-CSAH.html
http://www.racetronix.com/RX-LS2-KSRH.html
Just a couple of things to consider...
