Is this ok to clean a throttle body with?
Old 11-03-2006, 05:58 PM
MjMaro's Avatar
Default Is this ok to clean a throttle body with?
Will steel wool and regular dish soap be alright to clean out my TB, don't want to screw anything up. Thanks
Old 11-03-2006, 07:11 PM
bsf
bsf's Avatar
I have used Simple Green and hot water after removing the sensors. I just made sure it was well rinsed and dry before reinstalling the sensors.
Old 11-03-2006, 07:16 PM
Tainted's Avatar
should be, i used carb cleaner
Old 11-03-2006, 08:29 PM
02gixxersix's Avatar
Anything that is safe for aluminum should be fine. I used parts cleaner but seafoam is what I'm gonna try next. Might let the **** soak in there for a little wihle.
Old 11-04-2006, 12:55 AM
MjMaro's Avatar
Thanks guys, i thought it would be ok but I didnt want the shaft that the blade is bolted to to end up sticking or rusting internally.
Old 11-04-2006, 01:28 AM
staringback05's Avatar
use a carb cleaner, dish soap tends to leave a residue behind regardless of rinse.....i wouldnt use that anyway....thats something your wife should be using....theres a "man rule" on that somewhere
Old 11-04-2006, 04:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
B-12 chemtool worked wonders on my TB.
Quick Reply: Is this ok to clean a throttle body with?
