Rear end question
Old 11-03-2006, 07:11 PM
BA98TA's Avatar
Default Rear end question
A friend of a friend is selling a rear end. He claims it is a 12 bolt, but I am not so sure it is. He said it came out of a 3/4 ton pickup, but it only has 10 case bolts.
Can anyone tell me any way to verify if it is truely a 12 bolt or if it is a 10 bolt?
Old 11-03-2006, 07:12 PM
Revelation Z28's Avatar
its a 8.5" 10 bolt rear.
Old 11-03-2006, 07:15 PM
Tainted's Avatar
another pos 10 bolt. if you get a 12 bolt go w/ strange or mooser
Old 11-03-2006, 07:20 PM
s346k's Avatar
the 8.5s can be built to withstand a lot of ****. i'd consider swapping a built 8.5 into an auto car with no brake, just to get durability and not lose 50 hp in turn.
BA98TA's Avatar
thanks for the quick responses guys!
Old 11-03-2006, 07:31 PM
its .3" less than the 12 bolt's 8.8" so now much difference. but the 12 bolt has a sturdier caseing.
Old 11-03-2006, 07:42 PM
BA98TA's Avatar
so in your opinion what is the best way to go for a built rear end?
Old 11-03-2006, 07:44 PM
Tainted's Avatar
mooser or strange 12 bolt with 1/2 studs, the better rear end cover, 33 psplien axles and all the goodies
Old 11-04-2006, 08:46 AM
jam01's Avatar
i never heard of mooser, moser's are quality rear's. mine cost over $2,500. but you get what you pay for.
Old 11-04-2006, 08:54 AM
Kleeborp the Moderator™
MeentSS02's Avatar
The 12-bolt designation doesn't come from the case bolts - it comes from the number of bolts on the ring gear.
Old 11-04-2006, 09:10 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Thank you Steve. It is just like people measuring width of a Ford 9" housing. Once again. Ring gear.
Old 11-04-2006, 09:23 AM
Tainted's Avatar
GAWD! I always end up putting 2 o's in mooser, they needa change their name
Old 11-04-2006, 09:58 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are you stoned?....you just did it again!
Old 11-04-2006, 10:02 AM
Tainted's Avatar
son of a bitch!!!!!!!!!
sorry Im sick witha cold and have had quite a few things this morning so im off in lala land for a bit
Old 11-05-2006, 08:09 AM
HavATampa's Avatar
Thumbs down
Doesn't matter what size it is if you are planning on putting it in your TA. If it came out of a truck, it's not going to bolt up.
Old 11-05-2006, 08:26 AM
LSXNV's Avatar
without spending the big bucks? find a 9" ford out of an early ford pickup. you'll have to do some work getting it set up for your car, but you can take pride in your rear.
you can also find other 9" in things like torinos, lincolns, mustangs, vans, tbirds and so on from the seventies and eighties.
Old 11-05-2006, 08:59 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah, but getting all that setup and replacing 25+ year old parts starts to add up.
Old 11-05-2006, 10:00 AM
LSXNV's Avatar
true, but i will let you all in on a little secret.
check out the catalogs made just for stock car racing. and the sites that sell used racing parts. alot of these companies even make custom tubular a-arms for alot less then the cost to buy them from jegs or summit.
Old 11-05-2006, 06:35 PM
Azrael's Avatar
I actually was just about to post this (only read a few posts) and then I decided to stop and read what you posted Steve, because I figured you would have something useful to add! Hahah...
Lol, jeez everyone is covering all the good points!
