Stock Headers off, Stock gasket question
Old 11-06-2006, 04:16 PM
timmkish's Avatar
Default Stock Headers off, Stock gasket question
OK, so I got the stock headers off this past weekend. Going with everyone's advice and going to keep the stock gaskets. Question is this: Should I clean the gaskets? If so, with what? Thanks!
Also, Is there a special tool for getting the spark plug wires back ont eh plugs, once I hook everything back up? Haven't got to that point yet, but not looking forward to it either!
Old 11-06-2006, 04:18 PM
Tainted's Avatar
actually if i were you, dont re-use the stockers but just get new ones. they arent but 20 bucks
Old 11-06-2006, 04:37 PM
Has Unresolved Sales In Feedback/12 second club
notatruews6's Avatar
I reused my gaskets on my slp long tubes with out any leaks, just take a wire brush to clean up the surfaces, or just replace them. There is no special tools to install plug wires, just press on the rubber boot till you hear a "click noise".
Old 11-07-2006, 01:35 AM
Shallow Bay's Avatar
You want one click on the spark plug and two clicks on the coil.
Old 11-07-2006, 07:13 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I have used the same gaskets 2 times...havent had a problem yet.
Old 11-07-2006, 07:26 AM
BIG_MIKE2005's Avatar
As already stated, just use your stockers. Hell, I didn't even clean mine. Still no leaks.
Don't worry about the plugs & wires, they aren't as bad once the LT's are in. You will actually be able to get to them easier. And once again as stated above listen for the clicks on the plug & coil.
Old 11-07-2006, 02:08 PM
jmm98LS1's Avatar
Same here.
