Ported Throttle Body
Old 11-06-2006, 07:58 PM
blkbird's Avatar
Default Ported Throttle Body
Hey guys, just wanted to see what your opinios were on the job I did. I could probably be a little better, but just wanted to see if it was good enough before I throw it on the car. Thanks.
The last three pics are of the completed work. Let me know what you think!!
I put it on and had no issues with it idling or anything. Comparing it to the one I had on there , BIG DIFFERENCE!!!! Im gonna take it for a test run later on tonight!!!
Attached Thumbnails Ported Throttle Body-tb-001.jpg   Ported Throttle Body-tb-005.jpg   Ported Throttle Body-portedtb-005.jpg   Ported Throttle Body-portedtb-006.jpg   Ported Throttle Body-portedtb-007.jpg
Old 11-06-2006, 08:04 PM
ChaseSS's Avatar
that looks pretty damn good, how many have you done before this or is this your first?
Old 11-06-2006, 08:07 PM
blkbird's Avatar
This is the first one I have done. I didnt get a chance to polish it up though. Thanks!!
Old 11-06-2006, 08:13 PM
marthastewart's Avatar
Looks good to me. I would finish off sanding it nice and smooth so their is no scratches, polish er up, and slap it on......!
Old 11-06-2006, 08:16 PM
blkbird's Avatar
What is the best grit paper or what do I use to get rid of the fine scratches?
Old 11-06-2006, 09:08 PM
02TransAm/Batmobile's Avatar
can't really tell from the pics but make sure the lip is razor thin, . . the lip, being thick, creates tubulence, .
Old 11-06-2006, 09:09 PM
Snuffles's Avatar
400 should be good, you can go to 600 if you want.
Just depends on how shiny you want it.
Old 11-06-2006, 09:10 PM
Snuffles's Avatar
What method did you use to port it?
Old 11-06-2006, 09:40 PM
blkbird's Avatar
I used a dremel to get the bump out and then i used 150grit and then 220. I guess I have a little bit more to go. Where can I find the 400 grit??
Old 11-06-2006, 10:12 PM
I used 80 then 400 then 1200, put a little polish and buffed. Had a mirror finish!
Old 11-07-2006, 08:35 PM
blkbird's Avatar
Almost done. Will post up pics in a bit and tell me wut you all think!!
Old 11-07-2006, 08:38 PM
WILWAXU's Avatar
Nice work!
Old 11-07-2006, 09:49 PM
blkbird's Avatar
Ok. Pics are up.
Old 11-07-2006, 10:03 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Looks good on the pictures.
Old 11-07-2006, 10:05 PM
blkbird's Avatar
Yeah, comparing it to the old one, it was all rough. It took me a couple of days but I finally got it right and im pretty pleased with it.
Old 11-20-2006, 12:51 PM
02gixxersix's Avatar
I go to 600 then use a polish and then an emory paper. Clean it up and it looks great.
Old 11-20-2006, 12:54 PM
bjamick's Avatar
ya i would love to get mine done but i dont have a dremel . but yours looks awesome man great job.
Old 11-20-2006, 01:30 PM
Snuffles's Avatar
I've never used a Dremmel.
You can go to any hardware store and pick up a drum sander with some extra sleeves.
Works great on the end of a variable speed drill or compressor.
It'll cost you ~$7-10.
That's all you need to port a TB.
Old 11-20-2006, 04:50 PM
Red99TA's Avatar
I use a drum sander and go from coarse to medium to fine on the drums then 80 grit to get rid of the gouges from the drums followed by 120, 150, 220, 400, 600, 1000, then a polisher with compound...mirror finish
Old 11-20-2006, 05:10 PM
Ragtop 99's Avatar
400 grit is available at home depot or at autoparts stores. Since you have a dremel, you can get some polishing paste and clean it real nice. Hit it quickly with the 400, then switch to the dremel and paste.
BTW, nice work.
