TB question
TB question
i just have a new throttle body it cames with a spacer but it's not open behind the throttle sensor some people tell me if your car with a cam put it if not remove it just put the open side of the sensor gasket it that true
i'm saying that there is acarbon sensor in the back of the throttle body when i buy it it cames with a spacer but the spacer is not open around the carbon sensor that's what i mean
http://www.csvaustralia.com/eshop/catalog/images/tb.jpg
this black spacer is closed
http://www.jhp.com.au/img/products/e....jpg?imagealt=
here behind the TB there is a hole for the carbon sensor when you put the spacer it willl be closed is that ok?
what
__________________
I don't want to hear about your RWHP numbers, It's all b.s.. Figuring a conservative 20% powertrain loss, a stock 305 h.p. Z-28 puts a realistic 245 h.p. to the wheels! And runs 13.60's. At 400 RWHP, the same car would be running mid 11's!
this is the dumbest qoute iv ever read.dynoes dont lie.not every drive train uses uses the same amount of power.20% is not acurate.the 305 hp is way underrated do research.
Originally Posted by 5_02ls1
__________________
