85mm MAF- Which is better
Old 11-14-2006, 04:04 PM
BBBBadSS's Avatar
Default 85mm MAF- Which is better
Which 85mm maf is better, the Z06 or the SLP one. Or is the slp maf basicly a z06 maf? Im sure they flow the same but I mean easier to tune.
Old 11-14-2006, 04:11 PM
RrCoX22's Avatar
neither... stick with the stocker
the slp is actually a grantelli one just w/an SLP logo... but they should both flow and tune the same (although i have tuners having problems with the SLP)
Old 11-14-2006, 08:39 PM
BBBBadSS's Avatar
It seems kinda defeating the purpose of having a 90mm intake/tb, 85mm lid and having the stock size maf (not sure what size stock is but know its quit smaller).
Old 11-15-2006, 01:29 AM
unSStoppable's Avatar
you put on an ofter market MAF you will pull an SES code. The stock MAF is good for a decent amount of HP
Old 11-15-2006, 05:57 AM
300bhp/ton's Avatar
It's not.
Although the MAF is smaller the air will flow thru it faster. It's proven that the stocker can handle way in excess of 500rwhp.
Plus I read a thread a while back where I think it was Tony @ AFR claimed on a h/c/i bolt on LS1 making around 480rwhp a 85mm MAF (when tuned) was only worth in the region of 3-5bhp.
Old 11-15-2006, 09:00 AM
lsx24's Avatar
Neither, of sorts,
A PACEparts CALIBRATED Z06/ls6 MAF is best. Why? Because it is calibrated, the tuning numbers for the range of MAF digital signals corresponds to stock ls1 tuning, not stock z06 tuning, which is very DIFFERENT. Most likely there would be little to no tuning required, but it's always smart to get a tune when you combine lots of parts (do it at the same time when you add headers and other boltons to save money).
As far as a 85 mm actually being worth it, that's debatable. I have not seen solid proof either way, except for my own testing, which showed better throttle response with the larger MAF, much like porting the TB.
I say this over and over, I can't see why porting the TB would have gains, and going to a larger MAF does not. Until someone can prove that, I am going to say it's worth it on a bolt on or above car.
Old 11-15-2006, 09:04 AM
torlak_t's Avatar
can we use slp(85mm) on 98 camaro? and is it gonna be different than the stock one?
Old 11-15-2006, 07:15 PM
BBBBadSS's Avatar
Im getting a new tune this spring anyway.
Old 11-15-2006, 07:19 PM
BBBBadSS's Avatar
Originally Posted by 300bhp/ton
It's not.
3-5 hp would be worth 150 bucks.
Old 11-15-2006, 09:04 PM
Ferocity02's Avatar
The SLP 85mm MAF sensor is the SAME AS the Z06 85mm MAF sensor which is the SAME AS the Delphi 85mm MAF sesnor.
Old 11-15-2006, 09:11 PM
Cop Car's Avatar
just delete the damn thing
Old 11-15-2006, 09:22 PM
wannafbody's Avatar
I like my Pace unit. Feels like it's worth a few HP.
Old 11-16-2006, 03:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Old 11-16-2006, 03:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I doubt that you can feel that. IT is one of those all in your head things.
Old 11-16-2006, 08:41 AM
lsx24's Avatar
I felt a tangible difference after installing my PACE calibrated MAF sensor. It seemed like the car picked up throttle response accross all rpm ranges. I bet it was worth more than a few hp.
Ask anyone if they felt a difference with a ported tb, and most will say yes. A ported tb has been shown to give an additional 10 hp alone.
I'd be interested to know how each of these units is calibrated. I can tell you for sure if you pop a Z06 MAF straight off a vette, you're going to be in a world of hurt because the frequencies don't line up. So, therefore, PACE [and possible SLP--I don't know for sure] somehow takes this into account with their units. I doubt PACE and SLP have the same exact calibration, so I bet that would explain the difference in results between the two. You never hear of anyone with a PACE unit having any problems.
Old 11-16-2006, 02:38 PM
RrCoX22's Avatar
you may pick up a few rwhp (if that, at any) but your definetely not going to feel that (more of a mental thing like jordan said)
this is more a mental thing also as it's very hard to actually feel a "seat of the pants" difference from just approximently 10rwhp although numbers wise, yes you can see that it's there and possibly a crisper throttle response
Old 11-16-2006, 02:45 PM
Cop Car's Avatar
things you do not feel a diffrence from:
ported tb
bigger maf
descreening your maf
K&N filter
putting NOS octane booster in your gas tank
feel free to add to the list.
Old 11-16-2006, 02:59 PM
RrCoX22's Avatar
ported tb
bigger maf
K&N filter
bump stop mod
tb bypass
lid
Old 11-16-2006, 04:51 PM
Cop Car's Avatar
T stat change
tune on stock car
switching to Flowmaster muffler (actualy you might be able to feel the car being slower)
Cold air intake kits
K&N FIPK
Old 11-16-2006, 04:57 PM
pcsmits's Avatar
ive got a 85mm slp $100 shipped only used about 10 miles let me know if any 1 wants it
