Legal CA exhaust
Legal CA exhaust
So i have LT's and ORY now and I want to tame it down and be completly legit, so I have started looking into shorty's or any other legal exhaust manifold.
So far:
http://www.edelbrock.com/automotive_...d_shorty.shtml
http://www.jbaheaders.com/results.asp
my second question is y-pipe and cat's, I assume I could have a shop mock me up one but what cats should I throw in there (random tech's?)?
any pictures and comments would be great
So far:
It's still not gonna be completely legit, which is what you're saying you want, unless you have the factory catalytic converters on there.
Why don't you just put cats after your Jet Hots?
I've looked extensively into the whole emissions deal. Let me summarize what the little paperwork slip says that came with my 2 new magnaflow cats.
-Cats are covered by the emission control warranty for 8 years or 80,000 miles.
- Fed. law prohibits replacement, tampering, movement of the location.
So basically, you can only replace them if they FAIL. What you replace them with are brand new factory-spec ones that a Chevy dealer will order.
I mean this slip wants me to give all this info to Magnaflow:
My name, address, phone, vehicle description including year, engine, mileage, what emissions level the car meets, and the facility representative from where the work is being done.
So, when you tell me you want to be straight-arrow by doing it YOUR way, I'm telling you that you're not.
I've looked into this more than once before.
I haven't got this crap on my car yet because I'm trying to find an installer who will risk their business license and/or large fines in CA for TOUCHING the cats. K?
LS1Tech Administrator
Received 1,467 Likes
I used to run what you would call a theoretically legal CA exhaust. I had JBA shorties (which have a carb number) and magnaflow cats (which I believe some also have a carb number) into true duals. Unless you're going to a referree station, you will pass at most places, as the cats were in the original location (they just check for the existance of cats), and I had shorites. Ymmv.
yeah cats back to original locations and then the shortys problem is the shortys need a carb # and most put that # in a unreadable place, anyone have any ideas of where the carb # is on the edlebrock or JBA headers or the pacesetter shorty's?
My cats have a carb number for them too but it doesn't mean that I can legally replace them. You can replace the cats only if they have FAILED after their 8/80,000 federal warranty. Not, "Oh his car's a 98 so he can."
Do I care? No, but I want to keep dnm informed just in case.
And as for holding the CARB number for an inspection, roadside or at a smog check, if you're buying the short headers new then they more than likely, I don't know because I've never bought them, come with paper work that says they're California Air Research Board approved.
So far:
So far:
yeah your not gonna have problems with carb #'s i have seen them in action they are like the man telling the man what do to. As far as cats if they are not attached to a set of LT's and they are in generall the stock location dont expect in problems in Cali. Basically you need Carb #'s and cats. I put a high flow cat on my 90 bronco back in the day and it passed fine at a referee station in sac and the cat had been moved a little, no problems though. basically is there any other shortys that have a carb # besides:
JBA
Edlebrock
Pacesetter
and with any of those where is the carb # or does it come with a sticker? also any photos of these installed. I am leaning towards the edlebrock's
JBA
Edlebrock
Pacesetter
Originally Posted by import slayer
I just switched from shorties to LT's and I love it. I HATED having shorties in my car. By far the biggest waste of money I put into my car.
looks like your not concerned about passing smog either are you?
Originally Posted by orangeapeel
Are they mouth tested for good scavenging?
