Throttle Body P&P/Bump stop mod
Old 11-16-2006, 12:52 PM
LS1Formula01's Avatar
Default Throttle Body P&P/Bump stop mod
I was wondering if anybody might have any links to websites that show how to's for the port and polish, and bump stop mods?
Old 11-16-2006, 01:22 PM
00formLs1's Avatar
do a search there are a bunch.
Old 11-16-2006, 01:36 PM
blkbird's Avatar
http://www.geocities.com/wilwaxu/throttlebody.html
Here ya go!!
Old 11-16-2006, 02:11 PM
00HARDZ28's Avatar
Just take your time look at my avatar took me 1 hour with the dremel and 4 hours of sanding with one sheet of 120 grit turned into 1000 grit and some burns and blisters on my thumb and index.
Good luck.
And putting the tubes in the holes does nothing for hp.
Old 11-16-2006, 02:42 PM
RrCoX22's Avatar
search and the stickies are your friends... you must have slip through the newbie initiation
Old 11-16-2006, 03:42 PM
blkbird's Avatar
I didnt put any tubes in mine either...... This was my finished product.
https://ls1tech.com/forums/generation-iii-external-engine/604476-ported-throttle-body.html
Old 11-16-2006, 03:56 PM
Cld069's Avatar
http://www.installuniversity.com/ins...sity/index.htm
Theres a write up with pics on the how to for the bump stop mod.
Old 11-16-2006, 07:32 PM
t/a for life's Avatar
if you wanted a pro to port your tb where could you go for that i dont want to f anything up ya know....
Old 11-16-2006, 10:44 PM
Pewterpower's Avatar
Bumpstop mod
https://ls1tech.com/forums/showthrea...7&page=1&pp=10
Old 11-20-2006, 12:44 PM
02gixxersix's Avatar
I do them. I have one that is almost done minus the cleaning of the exterior that has the bump stop mod, half-shaft, almost mirror finish, knife bladed the front end of the blade, and has the drill mod for a bigger cam. I can epoxy the hole for the drill mod if you would like or from what I am told you can just let your car run until it relearns its idle. I think this one could go for $100 plus your core.
Old 11-20-2006, 12:49 PM
bjamick's Avatar
ya theres an awesome write up on the bump stop mod that a guy did on here that wasn't stickied and should have been bc it had nice pics and step by step instructions. I followed that one and had no problems really didnt feel any gain from it though.
Quick Reply: Throttle Body P&P/Bump stop mod
