Ported a little too much of my throttlebody!
Old 11-16-2006, 05:14 PM
Red99TA's Avatar
Default Ported a little too much of my throttlebody!
So I thought I'd give porting a shot and apparently I took off too much material I now have a very small hole in the TB as shown in the pics. I had to shine a light on the other side of it to get it to show up in the pics. I'm done porting it (no need to sand it smooth and polish the inside as it's only going to marginally help air flow) but can I still use this thing? I was thinking maybe a little glob of JBWeld in the hole on the outside of the TB and then sanding it smooth. Do you guys think that would be ok? I really don't want to buy another one on ebay. Oh and it looks like there's still a ridge where the metal goes from smooth to rough (where the TB blade usually sits) but that's not true...it's actually a smooth transition with no obstructions
Old 11-16-2006, 05:33 PM
02gixxersix's Avatar
I have one that is almost done if you need it. It has shaft cut, the bump stop mod, the throttle blade knife edged, its ported and polished very nicely, and has the throttle blade drilled out. I am just waiting/deciding whether to fill the idle bypass or not.
Old 11-16-2006, 05:35 PM
Red99TA's Avatar
thanks for the offer but I already cut the shaft now I just need to grind it down for the bump stop. I want to salvage this one if at all possible.
Old 11-16-2006, 05:36 PM
non-sponsor soliciting not permitted.
Old 11-16-2006, 06:00 PM
mpsoldier's Avatar
jb-weld it?
Old 11-16-2006, 06:14 PM
presto_z's Avatar
IT IS GARBAGE.. so you might as well send it to me..
i think JBWELD should work just fine.. i would apply it from the outside of the TB and then sand it smooth on the inside (very carefully).. make sure the outside of the TB is really clean befor u put the JBWELD on
Old 11-16-2006, 06:22 PM
blkbird's Avatar
I dont see why some jb weld wont take care of that. Give it a shot, what have you got to lose....
Old 11-16-2006, 06:29 PM
Jantzer98SS's Avatar
I will send you some 2 part epoxy. PM me. I've done it before. It will be fine.
Old 11-16-2006, 06:40 PM
HeapaShifter's Avatar
That happened on my throttle body. You can just use some epoxy to cover the hole. No reason to get rid of the throttle body.
Old 11-16-2006, 08:05 PM
S99TA's Avatar
epoxy it on both sides and then sand it smooth. that's what i did when i got to crazy with the grinder
Old 11-16-2006, 09:21 PM
Ericbigmac83's Avatar
Jbweld is your best friend, apparently you missed the go easy cause some parts of the throttle body are thin warning, lol
Old 11-16-2006, 09:25 PM
bayer-z28's Avatar
Originally Posted by mpsoldier
jb-weld it?
+1. Another vote for JB Weld... GREAT stuff.. ROCK hard and bonds to almost ANYTHING!
Old 11-16-2006, 09:39 PM
Jeremiah's Avatar
JB weld will work just fine.
Old 11-17-2006, 12:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Man! You hogged that bitch out! Probably close to a 79mm now.
Old 11-17-2006, 01:31 AM
Beasst8's Avatar
OOPS!! Fixxable though.
Old 11-17-2006, 01:36 AM
mvvette97's Avatar
JB it and don't forget to do the bump stop mod
Old 11-17-2006, 02:05 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah. JB would do the trick fo-sho.
Old 11-17-2006, 09:10 AM
Ragtop 99's Avatar
I did that to one of the TB's I ported. I used JB Weld or metal filler and it worked great. Nice thing about the TB is that it doesn't get super hot and there is not a lot of stress put on it.
Old 11-17-2006, 10:02 AM
2000TransAmWS6's Avatar
i did the same thing on mine, my dad had some high strength metal adhesive (similar to JB Weld) that he uses on some of his models, it worked great. i've driven the car alot and checked it several time, and shows no signs of letting up.
Old 11-17-2006, 11:53 AM
armkneez8's Avatar
Put some gum.LOL, JB weld will do the Job. Good Luck!
