Gasoline smell out of exhaust
Old 11-20-2006, 06:22 PM
irnbru83's Avatar
Default Gasoline smell out of exhaust
Replaced OEM exhaust with magnaflow catback last night and i've been getting a lot of gasoline smell coming through the exhaust. Any ideas why changing the catback would do this?
(everything under the car is stock other than catback).
Old 11-20-2006, 06:25 PM
Starz T/A 17's Avatar
Is it just running rich b/c after freeing up the exhaust its going to run a little richer
Old 11-20-2006, 10:46 PM
irnbru83's Avatar
can i fix that without a tune?
Old 11-20-2006, 11:05 PM
Tech Resident
ChocoTaco369's Avatar
it should fix itself over a few drive cycles. you should be set after ~100 miles of driving.
also, note that the magnaflow catback is stainless steel and stainless steel smells very bad the first few times its heated. you may be smelling the fumes from the heat treatment. it should go away in a short while.
Old 11-20-2006, 11:06 PM
Divergent Lightning's Avatar
letting the exhaust makes your AF ratio leaner, not richer. I would bet there is less baffling in the muffler which allows more un-combusted gasoline particles to leave the exhaust system.
I would drive it a little bit and let it learn a new fuel trim before dropping money on a tune.
Old 11-20-2006, 11:45 PM
Tech Resident
no, it makes you richer.
catback, longtubes = richer
intake, ported throttle bdy = leaner
the exhaust work increases the flow from the exhaust valves of your cylinders which makes you run rich. conversely, intake work increases airflow to the intake valves of your cylinders, making you run leaner.
in short:
better exhaust flow = richer
better intake flow = leaner
Old 11-21-2006, 12:10 AM
irnbru83's Avatar
thanks for the help
Old 11-21-2006, 12:27 AM
RrCoX22's Avatar
all new exhaust will smell PERIOD
...just give it a week or so and you'll be fine
Old 11-21-2006, 01:42 AM
ChaseSS's Avatar
in short:
well i have learned different... not trying to argue but I thought in a closed loop the PCM will use fuel trims to maintain 14.7 AFR... at WOT you could be running lean due to the added airflow being shown in the MAF and VE tables. LT's making you run rich is just an internet myth, thats why I learned from brad8266 in a discussion of this earlier.
Old 11-21-2006, 02:51 AM
True Performance's Avatar
sounds normal, my gmmg exhaust smelled bad for like 2 weeks
Old 11-21-2006, 02:58 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I have no cats. So I in turn have no room to talk.
Old 11-21-2006, 07:43 AM
irnbru83's Avatar
It could smell like a large sweaty anus for all i care... the sound is so much better than stock. just wanted to make sure it was acting normally :p
Old 11-21-2006, 12:06 PM
02trns_am's Avatar
Yep my Corsa smelled for about a week and even smoked a little at first lol....but its all good now
