what do you think.
what do you think.
I live in a smog **** state (ca) I want long tubes but they will fail me on visual. I have a hot cam which is tunned good and you would have to know your stuff real good to tell it has a cam, anyway it is an 01 so it has the better manifolds but I was thinking since the cats unbolt out I should get some old ones and hallow them out (btw I have a custom cat back y pipe and spintech muffler on it) and when I have to smog it I will just put the real ones back on.
is this set up going to get me any noticeable diference? what kind of hp gain would you expect?
Yes L-T will add some decent power to your car. However, you'd probably want to tweak your tune.
I'm not sure if hollowing our the cats will be worth more than 5 HP.
Do you have a dyno graph of your car with the hotcam? I'd like to see the results with stock manifolds.
