No Cats = Popping?
Old 11-23-2006, 11:59 PM
bLkWdOw SS's Avatar
Default No Cats = Popping?
My friend has an SS, We just put on some SLP headers, and a 3" ypipe leading out to his exhaust, i know people here have ran there car without cats and no popping so whats with the popping?????
Old 11-24-2006, 12:01 AM
Tainted's Avatar
mmm pop corn
Old 11-24-2006, 12:12 AM
Starz T/A 17's Avatar
theirs no backpressure or resistance in his exhaust so its flowing freely and thats what your hearing, solution, add a better muffler or some cats
Old 11-24-2006, 12:17 AM
bLkWdOw SS's Avatar
ok i see, well honestly i dont care if he fixes it or not and im sure he doesnt either, i was asking more for my self. I have almost the exact same set up but with cats. I wanted to get rid of my hi-flow cats and i didnt want the poping sound. Would it be better to just port my cats? would that add some backpressure?
Old 11-24-2006, 12:18 AM
taintedmeat's Avatar
I have cats and I still get popping.
Old 11-24-2006, 12:19 AM
Tainted's Avatar
leave them be
Old 11-24-2006, 12:32 AM
yea porting or gutting your cats will give you basically what your friend has an off road Y pipe so you will loose backpressure
Old 11-24-2006, 05:52 AM
BirdmanLS1's Avatar
Uh, im pretty sure it has more to do with exhaust leaks also... like mine for instance... i have leaks EVERYWHERE so i get a ton of popping. Im pretty sure if everything is welded up real nice you wouldnt hear it as much. Just a thought.
Old 12-28-2006, 10:17 PM
AutomagicLS1's Avatar
Yeah I have a TSP 3" ORY off my pacesetters and a SLP resonator off the y pipe and under load the car sounds ungodly mean but during shifts it makes a like platt/fart/ popping noise I think it has somthing to do with torque managment when it shifts but it may be the exhaust. I wont change my exhaust b/c of that b/c it sounds so mean when your in it and it flows really well
Old 12-29-2006, 01:48 AM
mpsoldier's Avatar
could it just be the air system is just more pronounced threw the new pipes?
Old 12-29-2006, 04:40 AM
subtlez28's Avatar
I dont have my header or catless y on yet so I cannot say 4 sure, but...
On my old Buick (which had no cats) I had a popping sound when I put a Flowmaster on. The sound was from the air-pump. The fresh air pumped into the exhaust was creating small combustions (or so I was told). Deleted the air pump-->popping was gone. Just food 4 thaught.
Old 12-29-2006, 09:16 AM
98Camarod's Avatar
The air pump is only on until the cats are at operating temperature. If your popping is only there when the air pump is on then, yes it would fix your problem. I ported my throttle body and changed to colder plugs for my nitrous and my popping has dissappeared.
