LS1 motor TQ Strap, who sells one, Help!
Old 11-25-2006, 04:13 PM
Restricted User
Lawnboy's Avatar
Default LS1 motor TQ Strap, who sells one, Help!
I want to put a TQ strap on my 01 SS,
I have FLP long tubes and Y pipe,
Even after some tweeking and adjustments the y-pipe is banging the floor when a medium to hard take off is done.
there is not much i can do , the clamp is actualy hitting the floor when the motor torques up,
I think a nice TQ strap will do the trick,
Who sells what i need?,
and other ideas?
Thank you for your help
Old 11-25-2006, 05:22 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thats an idea..I was going to put poly engine mounts in due to a bit of banging when floored, but this may work..alot easier. I am sure you can pick up straps anywhere..just need the right length.
Old 11-25-2006, 05:50 PM
Restricted User
Lawnboy's Avatar
that what i am figuring ,
and i heard the poly mounts carry more vibration through the car,
I am not too sure about that thou, its just what i heard
Old 11-25-2006, 05:53 PM
1BADAIR's Avatar
didn't notice any NVH changes after changing to ploy mounts.
Well I take that back . I did notice a NVH change- the Y-pipe bang was gone
Old 11-25-2006, 06:43 PM
The know it all's know it all
Sean Collins's Avatar
Try flex couplers behind the header in the front of the y-pipe. Use some 3inch slip on flex couplers. Secondly add an extra hotrod style hanger on the y-pipe right under the drivers seat. It will fix your bang without all of the drama and the polymounts that make the car a bit more obnxious to drive.
Old 11-25-2006, 06:54 PM
NHRAMAN's Avatar
Exclamation
Called my local Speed Shop and they have 12 different sizes/lengths/types of straps. Can get cable or metal strap type also.
Old 11-25-2006, 07:19 PM
landstuhltaylor's Avatar
interesting idea
