installing aftermarket catbacks
2 questions:
car is a 99 LS1 A4
i'm anticipating getting an aftermarket catback in the near future. i was checking out the condition of my stock catback and noticed that the clamp where the stock catback connects to the ypipe is rusted beyond belief. do you guys find that this is common? my car is a 99 but it only has 35,000 miles on it.
for those of you who have ran into this would you recommend just cutting up the bolt to get the clamp off, or soaking it?
Also, when these catbacks are installed, do you guys typically weld them up when you're done, or just leave them bolted and clamped.
on my v6, i had everything welded.
car is a 99 LS1 A4
That's what she said...
Originally Posted by Cummins
Sprayed mine with PB Blaster waited 2 minutes put the impact gun on it and it zipped right off.
I hammered a socket that was 4mm smaller than normal onto the bitch, then filled the socket up with PB blaster. Let it sit for about 30 minutes, then used my impact...................... on 150psi..........
You know what I always say...
"If it ain't broke........ fix it till it is..... "
Originally Posted by TheBlurLS1
PB Blaster + impact wrench will disassemble the ******* world. I wish I had taken pictures of the top of my stock shocks and the condition of the nut/threads.
