GMPP manifold with oem style mounting rails
Old 11-28-2006, 10:12 PM
SVC707's Avatar
Default GMPP manifold with oem style mounting rails
ive got this setup which was machined by one of the sponsors. but it is leaking fuel from the injector bosses and the fittings into and out the rails. ive tried teflon tape and paste. te injectors are just too loose on the injectors but in my speedinc rails they ARE VERY snug. i tried to adjust the two mounts bars that are used to set it all in place. but it still leaks.
who has made the speedinc or other rails fit in the threaded locations located in the same location as the oem rails do
Steve
