I need H-pipe Pics
Old 11-29-2006, 04:01 PM
BayAreaSS's Avatar
Default I need H-pipe Pics
Does anyone have pictures of an H-pipe dumped at the axle?
I want to take some pics to an exhaust shop to show them what i want.
How much does it usually cost to get an H-pipe made (dumped)??
Thanks
Old 11-29-2006, 05:25 PM
BerryWS6's Avatar
I just got quoted $330 for a 2 1/2" system with 1 chamber flows
Old 11-29-2006, 05:58 PM
BayAreaSS's Avatar
I just called a place and they gave me a break down of the price.
I will need 2 flanges to hook up to my LT's.....$8 each so it is $16
And for every bend in the exhaust it will cost me $18(mandrel bend)
And he said it would take about 2 hours. Labor is $75hr....So $150.
So its going to cost about $200 w/o mufflers. I'm getting 2 dynomax bullets.
(the price is for two mandrel bends. Do you think i will need more than two bends in this setup?)
I still want pics to bring them....
Old 11-29-2006, 06:59 PM
That's what she said...
TheBlurLS1's Avatar
You'll need some 45's and some **** to make it nice. I guess he means $18 for a 180* mandrel?
Check the TD sticky for inspiration, print some pics of a nice setup so he'll have something to go by. Tell them to remove the tunnel brace and flip the fuel line brackets the driveshaft tunnel for some more clearance.
Old 11-29-2006, 07:05 PM
BayAreaSS's Avatar
I think he was taking about mandrel u-bends. I read the entire TD sticky. I knew about removing the tunnel brace but never read anything about the fuel line brackets. I told him i would stop by so he could check out my car and show him what im talking about. It seems like he knows his ****. I really want to get a pic of my exact setup and a sound clip.
I heard an x-pipe with dynomax bullets dumped and i liked it. But the car i heard had a cam.
Old 11-29-2006, 07:19 PM
TheBlurLS1's Avatar
U bends = 180 lol. 2 x 90 = 180.
Keep your old exhaust so you can swap it in and try to pass emissions in Ca.
He can probably cut those 90's into a couple 45's if needed.
Old 11-29-2006, 07:23 PM
BayAreaSS's Avatar
I will keep my stock stuff.
I'm debating if i should go through the hassle of a custom H-pipe or should i just get an custom ory made
Old 11-29-2006, 08:24 PM
Phil8616's Avatar
either way I doubt you will pass emissions in Cali. Go for H-pipe duals or X-pipe duals, it cost me $500 for install and parts for my 3" x-pipe true duals with dynomax bullets dumped. Id think it would be near the same price for an H-pipe set up? Your quote is pretty good considering they are doing mandrel bends and not cutting and welding.
Old 11-30-2006, 02:47 AM
BayAreaSS's Avatar
I really want duals and i'm already going to be illegal with the LT's so i will probably go with the H-pipe and just try to find a hook up in summer 2008 when i have to smog again.
