Exhaust ticking
Exhaust ticking
A couple of weeks ago i installed Pacesetter LT with a TSP offroad Y. The problem I am having is a loud ticking noise coming from the passenger side, mainly underneath the door.
I have retorqued everything and cannot hear the ticking under the hood so i have ruled out bad gaskets (have gm stock gaskets)
I have searched and some say it could be bad pushrods or just loud valvetrain. I cannot hear it on the driverside or from inside.
I hope someone can help me or just help rule some things out.
if it is because of thinner primaries should the ticking sound also be on the drivers side.
I have done everything short of remove the headers to try and track this problem down.
Can it be a bad weld in the primaries collect at.
SSU, come over and relax
you didnt use the paper gaskets that come with the pacesetters did you??
if you did that could be your problem because those things are terrible....if you used metal ones then it is probably nothing since i have heard that putting on headers can make a tick noticable
Mine ticks too after header install. It only ticks and sounds weard when i go wot at low rpm's but once i pass 3500 it goes away or i cant hear it anymore. I have tried everything to find out where it could be coming from but nothing is leaking or making any black marks. I think that the long tubes just tick a little. Unless someone else knows something.
Originally Posted by TheBlurLS1
You will never ever get rid of the tick. I've been fighting it for 2 years. I've gone so far as to pull the heads and replace the lifters.
This place used to be called LS1tick.com
Hey if the slip fits on your y-pipe are leaking then do this. It fixed my problem.
I had 3 leaks on my tsp ORY. All where it slip fits together and one where it slip fits onto the driver's side header. I knew there was a leak there because of the carbon deposits on the collector. I got some header wrap and 3" band clamps.
Cut a piece of header wrap long enough to wrap around the pipe once. Nothing more. Then put the band clamp on it and clamp it down. This will seal it.
Do this on the y-pipe and where the y-pipe slips fits on the collector.
ya there's gotta be a leak in your exhaust... go re-check it.
obviously if you didn't have a tick before you swapped your exhaust.... well that rules out everything except, well, your exhaust
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by Cop Car
leaking y pipe. go back and tighten AGAIN. its one of the tradeoffs.
Check to make sure all of your spark plugs are on tight. I had the ticking for like a year and thought it was a header leak. I took out all my spark pugs, checked them, and reinstalled them making sure they were all in tight. The tick is gone.
