cleaning my intake
cleaning my intake
i have a ls6 intake that i bought from another forum. its kinda dirty as though its been sitting in a garage for quite some time. is there a safe way of cleaning it, inside and out, before installing it??
Originally Posted by Grimes
haha, vinegar....may i also suggest painting it a cool color before you install? It may be a bitch to mask off, but it will give a nicer custom look if done right.
Simple green will work most of the time, but my LS6 had like baked on oil caked all over it and that **** would NOT come off and simple green just turned it all red. I more or less had to sand it all off, even a pressure washer wouldn't take care of it.
Good luck, painted intakes always look great if you put the time into prepping it right.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I don't think that you can clean it if you didnt buy it off www.LS1tech.com.
LOL!
Actually carb cleaner and a rag will do wonders. Make sure that you pull the rubber gaskets off though if you chose to do that option. Not sure how that affects the integrity of the rubber material of the gaskets mixing it with something like carb cleaner.
That's what she said...
I've cleaned up some serious disasters with Gunk brand Foamy Engine Brite. My DD looked like someone took 10 gallons of mud/water dumped under the hood.
1 Pass with long bristled wheel brush + foamy, then 1 pass with simple green and clean brush, then thorough rinse/air dry = blang blang.
Here's what the stuff looks like....
