slp ls6 intake manifold?
planning on picking up the intake w/ egr prov. does anybody know if this comes with the ls6 coolant lines that are needed? on there site it says comes with all nec. hardware for install?or does the intake already come prepared for the swap so no ls6 coolant lines needed? if i still need them can someone drect me to the part#'s.
thanks
thanks
great. now its time to order and bolt on.
wouldnt still require you to still make the opening for the egr tube?
Originally Posted by jlrz28
Never seen anyone use this but a good idea with a cheaper ls6 intake.....
http://www.lingenfelter.com/Merchant...Category_Code=
Originally Posted by Cop Car
one of the few things id actualy buy from SLP
same here. if it wasnt for emmisions/smog here in cali i wouldnt be going this route. even though theres ones around that.
I bought the LPE part.
Makes the LS6 intake look completely stock to a LS1 intake. It's a well done piece.
Used LS6 + LPE part costs a lot less than the SLP lid, and if you grind down the fins on the LS6 intake, it will fit comepletely without having to remove the coolant tubes.
going price for LS6 intakes is around 350 without crossover coolant lines. IMO way to much when for like 4xx you can have a brand new intake, lines and gaskets
im ordering the slp one and it has everything i need for 490.00 shipped to my door.
That’s why I ordered a new SLP intake with the egr housing. I ordered it from LS1speed.com and it came with everything I need for an easy install. It didn’t make
sense to me to buy a used intake and then spend money on the egr block off plates, coolant lines and gaskets, why not just buy a new one that comes with everything and be done with it.
I received it today and will install this weekend.
Originally Posted by MyKeySS
x2 on that.
That’s why I ordered a new SLP intake with the egr housing. I ordered it from ls1speed.com and it came with everything I need for an easy install. It didn’t make
Originally Posted by harleyrider4ever1980
I know this thread is a little old but does the slp intake come with the egr block off plates as well? Also, I can't find it on LS1speed.com
the only reason to go with slp intake is for emmsions purpose or if you would like to keep egr for that. im in cali and egr is needed for emmsions so i opted for it. but if emmsions is not a concern and you have a 98-2000 ls1. you can get and intake form our sponsors or search the for sale section..
i recieved my slp intake earlier this week now need to find the time to install.
