crush bend true duals hp lose??
Old 12-07-2006, 05:02 PM
jlashley2001ss's Avatar
Default crush bend true duals hp lose??
hey guys....im going to do true duals over the axle and im wondering if I will lose HP going crush bends over the axle 2.5"? comments on this is greatly appreciated!
Old 12-07-2006, 05:04 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Good luck finding a straight answer...
Old 12-07-2006, 06:31 PM
are yours mandrel bends?
Old 12-08-2006, 12:09 AM
01bird58's Avatar
I have 2.5" over the axel set-up and one of the sponsors on here basically told me that I wont really be hurt HP wise until I start dipping into high HP ranges. Im guessing you can expect to lose a few HP with a H/C package but I dont think its anything to worry about. Shud have been getin my car tuned/dynoed saturday but they cudt squeeze me in
Old 12-08-2006, 01:10 AM
JEB Garner's Avatar
I have the stock manifolds, stock catalytic converts, used a "H" pipe. I picked up 15 horsepower with my dual exhaust system.
Old 12-08-2006, 06:44 AM
300bhp/ton's Avatar
I don't think it's so much will crush bends loose HP, but more like limit potential.
Not sure what rwhp you are putting out, but you are probably reaching where a 3" Y pipe is becoming a restricition.
2.5" duals flow significantly more than a 3" Y, so even with crushed bends you will likely see more potential. Although I suspect most of your gains would be from swapping the Hooker catback out. I'm not really a fan of the Hooker. Straight thru bullets on a dual setup will flow better regardless.
If you where nearing 500rwhp I think it should be more of a concern. But remember there have been many people who have sucessfully made well over 650rwhp still using a 3" Y.
So in short, if you're happy to go for crushed bends then I really wouldn't worry all that much. Maybe go 3" tubing where it's being crushed that way you'll retain a good pipe diameter.
Old 12-08-2006, 07:45 AM
well im putting down 370rwhp...so you think ill be ok and not really lose any hp?
Old 12-08-2006, 08:19 AM
01bird58's Avatar
^ If your making 370rwhp with a Y-pipe now and then install the 2.5" true dual set-up your talking about, you can expect your HP to only increase. You can't go wrong with a 2.5" over the axel. No ground clearance issues, awesome sound, flows better than Y, and fabrication price isn't through the roof.
Old 12-08-2006, 08:37 AM
^^^ even through crushed bends?
Old 12-08-2006, 08:53 AM
lsx24's Avatar
Yes, even through crush bends...it will flow plenty for your hp level.
Old 12-08-2006, 09:21 AM
300bhp/ton's Avatar
+1
Old 12-08-2006, 11:51 AM
MeentSS02's Avatar
Yes...all mandrel, all Tig welded.
