Underdrive Pulley Bolts and Belts
Old 12-10-2006, 08:46 PM
Ls1Envy's Avatar
Default Underdrive Pulley Bolts and Belts
I'm going to get an ASP UD Pulley, and was wondering if the belts have to be replaced?
I know theres 2 belts, one for alternator, power steering($30) and ones for the AC($14), do I need to replace both?
Also Can I use a new oem replacment balancer bolt on the new pulley?
Old 12-10-2006, 08:59 PM
SiL3NtXWS6's Avatar
yup
yup
yup
erikthegoalie's Avatar
you 100% can use a GM bolt...i recommend it...unless you want to spend like $30 on an ARP?!?!
you need shorter pulleys also...you can get those numbers from TR i believe....they sell the ASP and give the belt #'s...
