turbonator for your exhaust
Old 12-12-2006, 11:06 AM
BrandonDrecksage's Avatar
Default turbonator for your exhaust
http://www.spiralmax.com/tet.htm
hey, I want to buy this, do you think it will cause a big enough vortex to pull out my exhaust valves though?
BrandonDrecksage is offline
Old 12-12-2006, 11:17 AM
98Camarod's Avatar
If I see this on a car I will die
98Camarod is offline
Old 12-12-2006, 11:39 AM
junkz28's Avatar
oh wow.
junkz28 is offline
Old 12-12-2006, 12:47 PM
Tech Resident
ChocoTaco369's Avatar
if i ever see this on a car, i'm writing something insulting with my fingertip in their undoubtedly dirty back windshield.
ChocoTaco369 is offline
Old 12-12-2006, 12:49 PM
truglow's Avatar
It helps mix the rice.
truglow is offline
Old 12-12-2006, 12:59 PM
farnoush's Avatar
I got that and now my A4 car chirps OD at WOT.
farnoush is offline
Old 12-12-2006, 01:01 PM
AintQik's Avatar
Its their really slick website that one me over. I think my myspace is more professional looking.
AintQik is offline
Old 12-12-2006, 01:02 PM
brad8266's Avatar
"For the inserts, you can install one or more units"
Ya know the old ricer saying "The more the faster" More stickers=faster, more spiralmax=faster obviously
hahaha, this is at the top
The Turbo Exhaust Tube ™
Is best used with the SpiralMax ® Turbo Air Twister.
brad8266 is offline
Old 12-12-2006, 01:07 PM
LS1TECH Sponsor
Steve Burger's Avatar
I run them on my drag car. It makes the dust look like a tornado in the pit area. Oh I also have one on the truck. It looks really cool on the receiver when it spins on the highway.
Steve Burger is offline
Old 12-12-2006, 01:08 PM
sdbrown84's Avatar
The only addition I would make is that the spirals at the end actually spin. I think that would create the neccesary thrust to propel any 18 sec car right to a 12 sec timeslip.
sdbrown84 is offline
Old 12-12-2006, 01:16 PM
Torque_Wrench's Avatar
You know guys...the bad thing is...someone will actually believe that **** on the website....and buy one.
Torque_Wrench is offline
Old 12-12-2006, 01:24 PM
sapper_daddy's Avatar
Huh it was fake?
sapper_daddy is offline
Old 12-12-2006, 03:13 PM
That's what she said...
TheBlurLS1's Avatar
I think the performance breakthrough was discovered by the most incompetent person in the world trying to install it normally.....
TheBlurLS1 is offline
Old 12-12-2006, 03:58 PM
2 fast 2000's Avatar
2 fast 2000 is offline
Old 12-12-2006, 04:27 PM
jimmypop13's Avatar
i just installed 3 in my i-pipe and i bought the billet tips. It's like adding a turbo, I spin through 4th gear now! That's right, overdrive baby!
I love how they straight up almost say you won't gain ****:
Typical range of improvement over baseline is:
0 to 35 increase in horsepower,
0 to 31% increase in fuel economy.
(Actual performance may vary, depending on type of car, driver, and actual driving conditions.)
LOL you may get a 0 increase haha
jimmypop13 is offline
Old 12-12-2006, 04:37 PM
LS1Formulation's Avatar
That pisses me off almost as much as the "chips" they sell on eBay that give you 40 HP but only cost $6. Imbeciles.
LS1Formulation is offline
Old 12-12-2006, 05:24 PM
1999 SS's Avatar
i cant beleive some of you guys!!!
you wanna tell me after reading the customer testimonials you guys think that its all bullshit. you probably dont beleive in santa either and think strippers **** better than other ***** too. jerks
1999 SS is offline
Old 12-12-2006, 05:32 PM
Tech Resident
2001 WS6 Ram-Air Trans-Am preliminary results 41 hp gain!
I would like to report to you some initial results from using your SpiralMax product on my 2001 WS6 Ram-Air TransAm, which only had accumulated 4,300 miles at the time of installing the SpiralMax unit. As you may know, the 2001 WS6 Ram-Air TransAms are equipped with the intake manifold that comes standard on the Z06 Corvettes. This intake manifold has the general shape of the shell of a snail (consecutive circular rings) and is manufactured from a thermoplastic material, which keeps the intake charge cooler than conventional cast iron or aluminum manifolds.
the incoming air from the throttle body should closely match the profile of the manifold. SpiralMax produces a swirl-like air profile that very closely matches the profile (circular ring) structure of my TransAm's LS1 intake manifold. By inserting a single SpiralMax unit immediately before the single-bore throttle body on my 350 cubic-inch LS1 engine, my expectations were very high about the potential performance improvement due to this "matching" characteristic.
Before installing the unit into the intake hose, I disconnected both the positive and negative battery terminals and reconnected them to the battery the following morning approximately 11 hours later. The instructions state that the blades of the SpiralMax unit can be place in either direction with the intake hose. By using a small fan, I was able to determine that better swirling characteristics ere achieved by placing the blades such that they faced away from the fan. This situation would correlate with placing the blades such that they face the throttle body.
The stock intake hose, in which the SpiralMax unit was installed, was very short in length, due to the location of the Ram-Air box being very close to the throttle body. There was just barely enough room within the intake hose to fit two SpiralMax units back-to-back. Even though there is just enough room for two units, I only installed one unit. The next morning after the installation, I reconnected both battery terminals and fired up my Black Fury. I immediately notice a much improved throttle response, especially at full-throttle, which I expected. Using my GTEC Pro accelerometer, my rear wheel horsepower increased from 390 hp to 431 hp, a gain of 41 hp at the rear wheels! Needless to say, I was extremely impressed, especially since this improvement was achieved at 5,280 feet of elevation. I will be order a second SpiralMax unit shortly to determine if further improvement in horsepower gain can be achieved. I'll keep you informed about these future results as they become available. I will also keep you informed about the effects of the SpiralMax unit on gas mileage. for now, my baseline mileage is 20-22 mpg.
'til next time.
David (Engineer)
Denver, Colorado
http://www.spiralmax.com/spiral1.htm
i don't know guys, these spiralmax's are good for 41 horsepower according to GTEC. sounds pretty promising. headers and tune? pfft, a spiralmax is worth even more horsepower!
how many people actually know that the mpg increase they see is because they're babying the car looking for better fuel economy?
Old 12-12-2006, 10:02 PM
I e-mailed the guy asking if it was okay to put these in my ferrari f40. I told him i wanted to put a couple in. One before the turbo, after the turbo before the ic and after the ic and right before the tb. so that is 5 per turbo. I asked him what I should expect performance wise. waiting on a response..lol.
Old 12-12-2006, 11:30 PM
BerryWS6's Avatar
Sounds like somthing Uncle Reco would buy
BerryWS6 is offline
Quick Reply: turbonator for your exhaust
