99 stock manifolds to 2000+ manifolds
Old 12-12-2006, 07:53 PM
csmc711's Avatar
Default 99 stock manifolds to 2000+ manifolds
Okay, so, here I am thinking...........again. I am about to get a 99 for a good deal with a jasper rebuild in her that has 1k miles on the engine. Since, as I know it so far, I can not go long tubes for fear of failing visual emissions, would it be worth it to put on some 2000+ manifolds? What kind of increase would I expect? I have heard they are close to shorties, so, that would be??? Also, you can always scrounge a decent deal on ebay, but, whats the max $$ I should put out for them? Not gonna pay $300 for something that gives me 5hp, lol. Just curious as to the forums insight and opinions, thanks.
Old 12-12-2006, 08:47 PM
RrCoX22's Avatar
do even bother swaping out your '99 manifolds just for some '01-02's.... if your gonna swap anything and and need to stay emissions legal then shorties is your answer
...with shorties and a dead on tune you should expect anywhere from 10-15rwhp over your '99 manifolds
Old 12-12-2006, 09:34 PM
csmc711's Avatar
Yea, I hear ya. I was thinking if I could pick up a set for $25, a weekend playing around swapping them for 5 hp, would be cool, but, if the stocks wont net me anything, then, your right.
Old 12-12-2006, 10:18 PM
Cop Car's Avatar
stock 00-02 manis with gutted cats will get you the same gains as shortys.
swap them on btw
Old 12-12-2006, 10:43 PM
INMY01TA's Avatar
Check out Mac's website. They sell an off road y pipe for the stock 98-99 manifolds. I'd keep the manifolds you got and just get the ory and change that for inspections. The Y pipe's not to hard to change periodically.
Old 12-12-2006, 10:45 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I think you mean DON'T
Old 12-12-2006, 10:48 PM
lastcall190's Avatar
I have some 00 manifolds that I'll give to you for free if you pay shipping.
-J
Old 12-12-2006, 10:50 PM
Starz T/A 17's Avatar
If you change out for the different manifolds the emmission lines wont match up
Old 12-12-2006, 11:58 PM
RrCoX22's Avatar
you are correct! I do mean DON'T
-J
but either ways there's your hookup if you do decide to go the cheaper route...
are the '00's the same as teh '01-'02's with just an EGR provision?
Old 12-13-2006, 12:08 AM
csmc711's Avatar
Well, I need a new egr anyways and people are always plucking thiers off, so, thats about all I would need then after the manifolds, ehy?
maybe then gut the cats, maybe weld a stright pipe in there, or, just get flange crazy and have two sets of pipes. One for inspection and one home built Y that has one 3" cat where they used to put them back in the day so I am still running clean. With flanges all around, would be a breeze to swap back and forth when needed.
Old 12-13-2006, 01:14 PM
Cop Car's Avatar
im sure someone has an egr pump they will give you too
Old 12-13-2006, 01:17 PM
And if you get manifolds off a 01-02 they wont have an EGR fitting on them, only the 2000 revised manifolds had them
Old 12-13-2006, 01:53 PM
csmc711's Avatar
Sounds good, thanks for all the input guys, appreciate it.
