eliminating the EGR
eliminating the EGR
I plan to install an ls6 intake. Is there any reason to not eliminate my EGR. WI does not do underhood inspection. Will this set a code. Also where can I get a block off plate.
Ya all you need is some block off plates for the manifolds unless you get race headers which dont even have a spot for EGR. All EGR is is exaust gas recirculation ( i think) but its not needed just like the AIR stuff.. You need to read up on the how to's on how to remove it theres a whole bunch of stuff that is taken off. After this stuff is removed your car will throw a code but find someone with HPtuners around you to just turn it off and you will be fine.
