pacesetters clearance???
Old 12-16-2006, 04:34 AM
SLP/Drew's Avatar
Default pacesetters clearance???
how are the pacesetters LT headers with the off-road y pipe on clearance, I want to lower my ride about 1.5" with out the suckers scrapeing
Old 12-16-2006, 05:22 AM
DaGeneral's Avatar
Sometimes my ORY hits on speed bumps. This is at stock height...
Old 12-16-2006, 09:56 AM
lgobraves's Avatar
depends more on how well the y-pipe tucks up. pacesetters tuck up pretty decent. I'd get a custom one with the flowmaster merge and see if that would help your clearance
Old 12-16-2006, 10:17 AM
BIG_MIKE2005's Avatar
My Pacesetter LT's have great ground clearance. Its the 3" ORY that causes some loss of clearance. I scrape mine in certain parkin lots, but its not bad. I need to get the mufflex bump stop hanger for the ORY so it will stop hittin the floor.
Old 12-16-2006, 10:26 AM
jpat1023's Avatar
Exact same experience here. The actuall headers tuck up very nicely, its just the y-pipe that might cause you some problems. However, its pretty adjustable, so if you spent enough time underneath the car messin' with it I bet you could get it to tuck up pretty well. And +1 for needing the bump stop.
Old 12-16-2006, 04:09 PM
SLP/Drew's Avatar
thats awsome and all but how many of you guys have lowered rides?
Old 12-16-2006, 05:42 PM
Cop Car's Avatar
headers arent any lower than stock exhaust. y pipe is always whats low with pacesetters. dont buy the pacesetter y pipe, it just bangs the floorboard
Old 12-16-2006, 06:00 PM
382WS6's Avatar
I had the Eibach Pro-Kit lowering springs on mine. My Pacesetters never touched the ground once, but the ORY scraped constantly. I knew it was low when I was scooping up pine cones. And +2 on the bumpstop... that thing was damn annoying on hard launches.
Old 12-16-2006, 06:07 PM
jpat1023's Avatar
Hard launches?? ****, mine bangs on the 1-2 shift anytime I'm above 3000rpm...and since I have a 3000rpm stall, it get's extremely annoying!! Bump stop mod is next on my list.
Old 12-17-2006, 04:54 AM
SLP/Drew's Avatar
does anyone run with midlenght headers for lowered cars?
Old 12-17-2006, 08:24 AM
blkbird's Avatar
I have very little issues with my ORY. It scarped the same as with my stock ypipe. I have the eibach sportlines in front and the prokit in the rear. As far as the banbing on the floorpan, the poly motor mounts took care of that...
Old 12-17-2006, 08:28 AM
Juiced2000SS's Avatar
Lowered here ORY with no issues at all.
