cat problem
Old 12-16-2006, 10:11 PM
z28burner's Avatar
Default cat problem
the passenger side cat on my 98 z28 has developed a very loud rattle, when i pound on the cat i can hear something inside the cat move around, has anyone experienced this problem and if so what was the remedy? looking at the system it appears that i am going to have to remove the entire system to cut out the old cat, if i do not replace the cat and just weld in a piece of tube, will i have any trouble codes
Old 12-16-2006, 10:16 PM
2002 SS #476's Avatar
The catalysts inside the converter is coming apart.
Old 12-16-2006, 10:45 PM
z28burner's Avatar
any suggestions on what i should do??
Old 12-16-2006, 10:55 PM
Replace it with a factory one if you don't want to worry about your check engine light coming on. If you gut it, your light will most likely come on with a catalyst efficiency code. Sounds like a good time for headers and a y-pipe.
Old 12-17-2006, 12:17 AM
stroked383z's Avatar
i got a letter from GM the other day saying that they would replace the LH and RH cats from the dealer for free if there was a problem with them. it was for 2002 5.7's only.
Old 12-18-2006, 10:29 AM
lsx24's Avatar
Cat needs to be replaced. Time for high flow cats or you can get a stock like replacement from a low mileage ls1 from a boneyard.
Old 12-19-2006, 09:19 PM
SScott236's Avatar
I have an 01 and i got the same letter. I dont have cats though so i doesnt matter
