High Mileage Engine (Heads & Cam Swap)?
Old 12-19-2006, 03:32 PM
Dragonnnfire's Avatar
Default High Mileage Engine (Heads & Cam Swap)?
Well I am toying with the idea of Cam and Head swap but my car has about 111,000 miles. What step would I need to do to ensure the high mileage engine could handle the heads & cam swap? I am thinking of getting the TSP MS3 or MS4 and I already have Mti stage two heads.
Old 12-19-2006, 03:46 PM
can'tfindausername's Avatar
compression check couldn't hurt
Old 12-19-2006, 04:59 PM
JonB's Avatar
I agree plus I would change the timing chain and oil pump while your at it.
Old 12-19-2006, 05:10 PM
Prostreet performance said the motors last quite a long time so I figured I could get the most out of the motor and put a cam in it.
Old 12-19-2006, 05:54 PM
gnomee's Avatar
Depending on what kind of life it has had it should be okay. I think you should be prepared to have something bad happen just in case. If its your DD you may want to have a back up plan if it only lasts 2 weeks
