Anyone using a TQ strap , to hold the LS! motor from twisting?
I am looking into a TQ ratchet strap or other method to keep the motor from twisting and causing my FLP long tube header -Y-pipe from hitting the flore board.
i like to find out where you mounted it to and where you go it and what type you are using.
Thank you for your help
No need to use a tq strap. If you are still using the stock motor mounts replace at least the drivers side one with a polyurethane one. That what I did on my car and it solved the y-pipe banging problems. Hope this helps.
That's what she said...
I just ordered a Mufflex bump stop from Thunder racing
am going in stall it and see how it works, it suspose to stop 95% of most cases of long tube Y-pipe hitting the floor board.
Its on there web sight under Exhaust accesarys
