Motor Mounts
Old 12-22-2006, 02:31 AM
bitterchaos's Avatar
Default Motor Mounts
Okay....doing headers, and another major setback. We can't get that little 4-pin connector outta the alternator. Our hands arent small enough to get in there. Are motor mounts REALLY necessary? My car has 91k miles. I'm just about ready to give up on the motor mounts and go straight to putting in headers. What do yall think?
bitterchaos is offline
Old 12-22-2006, 03:35 AM
LS1>girlfriend's Avatar
i had a problem with that little bitch too. i ended up takin the alternater down as far as the 4pin's wires would let it, then i was able to take it out with a needle nose or 2 screwdrivers...i try to forget that PITA.
anyway... i did my motor mounts after the headers were in because my y pipe was banging during accel. i got poly mounts and i love em! no more y pipe bang, shift stick doesnt move nearly as much, and there is no noticable difference in vibration. along with the other benefits that i cant think of right now. deffinitly worth the time, sweat and blood!
LS1>girlfriend is offline
Old 12-22-2006, 11:28 AM
brad8266's Avatar
I would do the motor mounts while youre there. The connector really isnt that difficult, at least mine wasnt.
brad8266 is offline
Old 12-22-2006, 11:44 AM
1CAMWNDR's Avatar
This must only be a problem for poly mounts. I didn't touch my alternator when I put in my Spohn solid mounts.
1CAMWNDR is offline
Old 12-22-2006, 04:26 PM
Cstick's Avatar
What 4 pin connector? Oh the one I did not see and forgot about when I took my alt off to do the poly mounts. I found a new pin and made the wire a foot longer so it would be easier next time. You are doing the right thing putting the poly mounts in now with the headers, rather than later when you find your Y hits the bottom of the car.
Cstick is offline
Old 12-22-2006, 04:31 PM
GTObsessor's Avatar
Ur already in there, just buckle down and get it done while ur there. Ur stockers are more than likely cracked pretty badly anyways. Mine were after 7x,xxx miles.
GTObsessor is offline
Old 12-23-2006, 01:20 AM
Too late...gave up on it lol. I'm running open headers right now so no problems yet.
Old 12-23-2006, 02:30 AM
That's what she said...
TheBlurLS1's Avatar
You screwed yourself with that move.
TheBlurLS1 is offline
