how does placement of Xpipe or mufflers effect sound qualilty
I know the topic of which is better a Xpipe or Hpipe is better, or which muffler/bullit sounds better has been beat to death.
But I couldn't find and answer for placement.
would a Xpipe placed closer to LTs be more benifical or placed a little further down?
How does having mufflers say just before the axle (while still being piped over the axle and out the back) differ from have them near the stock muffler location?
Im looking to run Duals out the back and over the Axle. but im looking for the throatiest, crip note i can get.
The closer the xpipe is to the header collector the better.
Have you considered running 2.5" duals into a single full size dual-in dual-out muffler in the stock location? That will be the most refined sounding of the true dual combinations for our cars. I researched duals endlessly and came up with that combination to run because of several reasons number one being refinement.
Placement of mufflers does effect tone somewhat but if the system is still true duals and the same size it's not going to sound a whole lot different if they are before or after the axle. A more of a difference will be seen with whether or not they are routed over the axle and out the rear.
thanks for the input.
I am actually considering the Bassani true dual exhuast set up. the only thing i don't like about it is the fact of that wicked turn for the passenger tail pipe to come out of the stock location. to me it lookes to jumbled, even if it doesn't ristrict power that much.
and say if i was to put one maganapack on the pass. side tailpipe and run the dr side around like the SLP CME with a maganapack on that pipe, wouldn't it mess with equilization, sound funny no?
Im trying to work with what i can buy, I've been searching and searching for places around me to do a custom True dual setup, but the closest one is kooks, and i don't have the time to travel all the way to long island.
Im not even sure i know what i mean by crisp..........so heres a sounclip lol
this tone i like a lot
http://s70.photobucket.com/albums/i9...MagnaPacks.flv
this raspyness on the down rev is what i don't like. 15seconds in to 19seconds.
http://s37.photobucket.com/albums/e7...=WOTnocats.flv
and i guess its raspyness with the actual bassani system.
http://www.centralfloridastreetcars..../revinpark.wmv
Well you know what they say, form follows function. And you're right it doesn't cost a bit of hp.
Also, in those last two clips above, I don't think they are running cats. That will add some of the raspyness you mention on decel.
If you listen to the Bassani clips on my webpage, it doesn't have any of that raspyness to it, just clean sounding duals, and I have Magnaflow converters.
eeeeh hope i dont get shot, but i was wondering the same thing, i was going to place the mufflers actually as close to the headers before the X and have the rest of the tubing run all the way out to the back. would that make it quiter, bassier, weezyier? i know that if you stick it out to the very end and then tip it, it sounds basically like everyone elses dose taht posts up that are dumped, minus the super loudness. my goal is to try and make it deep, but still quite. am i even in the right direction? BTW i'll be going with spiral flow's for the muffler
I wouldnt go that route man.....
I would think that having the Spiral Flows right off the header would kill a lot of exhaust velocity from the headers. I believe you want to keep the velocity as high *** possible off the headers to help with scavanging. Where as towards the back of the car the exhaust has allready slowed down quite a bit and the mufflers would pose as less of a restriction. However I don't really have any experience with things of this nature, but that would be my theory.
I was told by magnaflow that you should take a crayon and touch the exhaust and where it stops melting the crayon is where you should put your x pipe. I understand that wasnt the question , but why put one on just for sound instead of function?
Mine do have a SLIGHT rasp between 2500 and 3000 RPM's, but it's very faint. Overall it's better and any catback I've ever heard and still has a much deeper sound driving around town.
