Why so much play at WOT?
Ok first of my car has 95.5k miles on it. I think I need motor mounts. I have replaced my t/a mount and trans mount with poly mounts. I am still on original GM motor mounts however. I have dropped the tranny once and let it hang pretty low unsupported to get some of the top bolts. I think this may have stressed the motor mounts even more. The deal is at WOT I have almost 2 inches of shifter play that totally seems abnormal. I can simply be in park and rev and watch the shifter have slight play also. I read somewhere that it isn't good to have motor mounts that are softer than you trans or t/a mounts. In my case that is what I have. Have any of you guys had this problem and what did you do to solve it? Keep in mind that I have already replaced the two mounts mentioned. Please just tell me motor mount may solve this.
Josh
TIA
Josh
TIA
I have an auto but when I put headers and an ORY pipe on with less the 3k on the clock, I noticed the stock mounts were too soft. I replaced the drivers side motor mount and the tranny mount with poly mounts to keep my Y pipe from beating the crap out of my floor pan.
Change them out. Should take care of your problem.
Good luck!
Good luck!
Thanks guys. As far as the mounts go, should I stay with poly's since the rest of my setup has poly's. I mean if I got 95k out of my stockers I don't have a problem using GM. However I have plans for this car to see above 400 rwhp within the next few months.
Josh
Josh
