ticking noise after intake sawp
Did a ls1-ls6 intake swap, pulled the egr/smog stuff and installed an underdrive pulley. started it up and I now a fairly distinct ticking sound coming from the drivers side. It is pretty consistent with the idle. I pulled the valve cover and everything looks fine. Any ideas? Could I have hurt something cranking the motor while installing the pulley?
i would checked the stuff you messed with. its more common somthing is leaking then an internal problem developing from an intake swap. sparkplugs and wires are usually the most common for me. if you added blockoff plates put your hand around them with the engine running if you feel air you found your ticking.
