TB bypass/ Water temp. sending unit install
Old 01-02-2007, 08:18 PM
LS69TA's Avatar
Default TB bypass/ Water temp. sending unit install
I was going through some pics and found the one of my TB bypass and Autometer water temp. sending unit install that I did. It was easy and cheap to do. You just need a 3/8" brass "T" fitting, and a couple of 3/8 barbed fittings for the coolant hoses. I used a self tapping screw with liquid teflon on the back side to attach my ground wire.
Old 01-02-2007, 09:33 PM
BitViper's Avatar
linkie brokie
Old 01-02-2007, 09:45 PM
LS69TA's Avatar
It was just working a minute ago..
Old 01-03-2007, 12:13 AM
SweeTbone's Avatar
Interested in seeing this but picture is not working.
Old 01-03-2007, 05:03 AM
LS69TA's Avatar
Is it showing up now?
Old 01-03-2007, 07:14 AM
erikthegoalie's Avatar
do you neccesarily have to use the self tapping screw for the ground, or can you ground the gauge anywhere?
Thanks buddy
Old 01-03-2007, 08:04 AM
LS69TA's Avatar
You have to ground the sending unit for the gauge to work. That was the only way I could think of doing it with the sending unit in the adapter.
Old 01-03-2007, 01:47 PM
LS69TA's Avatar
Are the pics showing up now? I can see one of them.
Old 01-03-2007, 02:09 PM
one pic is....
ahh yues yes youre right...it isnt grounded because of the rubber...cool idea man..i actually got an adapter for a plug to go in the passenger side head...i think itll work great....if it leaks or doesnt give me a good reading...this will be my next choice
Erik
Old 01-03-2007, 02:27 PM
LS69TA's Avatar
Cool..glad atleast one pic is finally showing up.
Old 01-04-2007, 08:21 PM
blackened's Avatar
tried the pass. side head. my header flange went to far over, so i just spilled a shitload of coolant all over the place. if you have headers, check to see if there is enough room to screw the adapter into place. so, i'll be trying the tee fitting tomorrow. just wanted to put that out there, my loss might save you a couple of hours.
