what additional install parts do I need for ls-6 intake?
Old 01-04-2007, 12:05 PM
senicalj4579's Avatar
Default what additional install parts do I need for ls-6 intake?
I am installing a ls-6 intake in place of my stock ls1 intake. what additional things do i need for the install?
Old 01-04-2007, 12:08 PM
brad8266's Avatar
You need the coolant crossover pipes and plugs or you can just grind down the ridges on the bottom of the intake in order to make room for the existing coolant lines that are under the intake. You might as well also pick up a set of new intake port gaskets.
I did the grinding to the intake, its really simple and only takes a few minutes.
Old 01-04-2007, 12:17 PM
thanks. iforgot to mention my car is a 98 if that matters? do i need the ls-6 tb or maf?
Old 01-04-2007, 12:22 PM
brad8266's Avatar
Originally Posted by senicalj4579
t do i need the ls-6 tb or maf?
No, your current setup will fit.
Old 01-04-2007, 12:55 PM
lsx24's Avatar
TSP has the coolant and plug kit F/S. ------------------------>
Old 01-04-2007, 04:24 PM
KurtRardin's Avatar
be sure to be super carefull with the oil sending unit. Most first timers snap it off. The brake booster hose snakes around to the back of the intake manifold and WILL catch the sending unit if you're not carefull. Its got a green plastic clip ontop of it. Its about the size of a roll of quarters.
Old 01-04-2007, 05:10 PM
yeah man thanks. i saw your other post about that. but really, thanks for the heads up man
Old 01-04-2007, 05:16 PM
KurtRardin's Avatar
this was all new to me when i noticed my oil pressure guage after first start up. Not knowing to see that dude standing up on the back of the engine nothing looked amis to me. But, to change it out wasnt that big a deal, the intake comes off much faster the second time, lol.
Old 01-04-2007, 07:58 PM
lol, yeah it comes off the second time faster cause you get pissed off from having to do it a second time lol
then you feel like smashin ****
then you wanna cry
when does it end
Old 01-05-2007, 12:15 AM
99kamarokid's Avatar
how do u know if u broke it b4 u put the new intake on, and does anyone have pics of it??
Old 01-05-2007, 07:29 AM
brad8266's Avatar
Well it is supposed to stand straight up. if you break it it wont be standing straight up anymore. You cant miss it.
Old 01-05-2007, 10:02 AM
KurtRardin's Avatar
Its on the back right side of the engine, and is stands about as tall as a roll of quarters. Theres a little plug in the center back there and then right to the right of it is the oil pressure sending unit. If nothing is standing up back there then just fish around behind the motor until you find that dude. It will still be connected to the plug. Its got a green plug.
Old 01-05-2007, 10:03 AM
lastcall190's Avatar
AFAIK when you reinstall everything, if your oil pressure gauge is MAXED, then it's busted. Of course if it aint standing up, there's a tell also...
-J
Old 01-05-2007, 10:06 AM
KurtRardin's Avatar
My new sending unit sucks. It reads like 15 more pounds than the stock one. And i know its bad because there aint a stock 98 with 91k miles that reads 55psi on the interstate.
Old 01-10-2007, 05:27 PM
brad, how well does grinding the ribs down work? does it still squash the coolant lines at all under the after installed ls6 intake? also, do you think i will definatly need the gaskets? thanks
Old 01-10-2007, 05:58 PM
BlackDuk98's Avatar
Hi, I will be doing an LS6 intake swap on my '98 bird soon and was wondering, do you have a pic of exactly what I would need to grind down if I were to use my existing coolant line? Thanks in advance
Old 01-10-2007, 07:00 PM
bad6as's Avatar
mine does
Old 01-10-2007, 10:04 PM
greysteel_M6's Avatar
I'll be doing this soon and would appreciate this as well, Thaks-
Old 01-11-2007, 01:21 AM
SladeX's Avatar
if you grind down the fins flat, it will make a dead on perfect fit. Of course you have to make sure to remove the plastic clips on the knock sensor wires. With the plastic clips removed, the wires are more or less loose. I just put electrical tape over it where it goes over the coolant lines and grinded down a bit extra over that area where the knock sensor wire goes over the coolant line.
Old 01-12-2007, 12:16 AM
Thats what i'm gonna do also. Save 50.00. My ls6 intake thats gonna be here mon. is brand new from gm and it has a egr hookup. I'm gonna just hook that right back up if I can. Do you know if I have to change anything or can I use everything on the ls6 that I used on the stock ls1?
