Duals vs SIngle C/B.... Weight and HP
Old 01-05-2007, 02:18 AM
bayer-z28's Avatar
Default Duals vs SIngle C/B.... Weight and HP
I was thinking.
What is the weight difference between a regular C/B exh like lets say Magnaflow, and a regular true dual exhaust? If TD's gain about 10hp over a regular exh system.
if 10lbs = 1hp. is the weight gain worth the HP gain, or does it even out? Extra sound and maybe an actual street/track gain of 5hp....
Old 01-05-2007, 04:04 AM
DreamState23x's Avatar
Hmm... I would think that dual would be a little lighter actually. I never weighed mine vs the old catback. If you have a dual system dumped at the rear axle you would have less tube since its not going over the axle, you replace that big muffler with smaller ones, and probrably would have no cats either, and no tips. I don't think there is going to be a big weight difference either way, but my guess would be that the duals would be less. 2.5 duals would be even less.
Old 01-05-2007, 09:32 AM
BADFNZ's Avatar
Duals are lighter.
Old 01-05-2007, 10:16 AM
lsx24's Avatar
It depends which muffler for duals. If you go with a single dual-in dual-out muffler for True Duals, it's going to weigh very close to a catback, just the extra piping going back to the muffler and out. If you were to run bullets and dumps, it might actually come in lighter than a catback. Either way you are gaining more tq with duals that outweighs the minor weight advantage.
Old 01-05-2007, 11:46 AM
BADFNZ's Avatar
Why would you use a dual-in/dual-out muffler for duals?
Old 01-05-2007, 11:50 AM
lsx24's Avatar
I guess you're not familiar with the Bassani True Dual Exhaust...
It places a single dual-in dual-out muffler in the stock location, then runs duals into it, and duals out of it. It's a compact way of running true duals on these cars, considering the packaging contraints.
I had the Bassani system on my car and gained 20 lb/ft of tq in the midrange over the stock ypipe setup. It sounded and performed awesome.
Old 01-05-2007, 12:08 PM
SiL3NtXWS6's Avatar
This is why i just stuck a bullet off each header. I saved the most weight while making the most power.
Old 01-05-2007, 07:25 PM
wldesyWS6's Avatar
"This is why i just stuck a bullet off each header. I saved the most weight while making the most power."
and what setup/power are you running? i see in your sig you run 9s....if so then you dont need the backpressure like bayer-z28 and the rest of us runnin 12 sec range 1/4 miles.....we need to take advantage of scavenging, or else thats what i would do- anyone object to that????????
Old 01-05-2007, 07:30 PM
mrr23's Avatar
bah, gain of what 20 lbs going from stock exhaust with 3" electric cutout to the bassani tru-duals? went .3 and 3 mph quicker. i'll take the trade off.
Old 01-06-2007, 12:59 PM
Ragtop 99's Avatar
Was that with the stock cats?
Nice pics on your website.
Old 01-06-2007, 03:39 PM
wldesyWS6's Avatar
SOMEONE PLEASE COMMENT ON THIS
Old 01-06-2007, 08:42 PM
Ragtop 99's Avatar
I object!
1) Back pressure is bad. It does not help whether you run 9's 12's or 15's.
2) Scavening is good, but the right headers with the proper extension will create that all by themselves.
The goal of the Y-pipe or duals is to get rid of the exhaust far enough back for safety, reducing the noise to a level you deem acceptable, while creating as little back pressure possible.
Old 01-06-2007, 09:20 PM
wldesyWS6's Avatar
anyone else agree or disagree with that? this topic just seems to be highly debated..
Old 01-06-2007, 11:15 PM
00454sscamaro's Avatar
+1^ i think open headers perform better then any dual setup... as ive tried a few of both and open headers makes the engine rev alot faster...... the only thing i wouldnt like about just open headers is the smell(even though my ms4/stage 1's going through big kooks smells beautiful and sounds like the devil reincarnated) the noise is also still an issue after 20 or 30 mins of driving. not sure how accurate this info is, sure heard it alot though- but without some extensions on the headers the o2's dont last as long.. and on a prevois car- 84 z28-355ci it smelled badly with open headers badly of unburnt fuel and had big backfires when letting off the gas..
Old 01-06-2007, 11:17 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
That is what that Bassani one is. I don't like it, nor do I know why.
Old 01-06-2007, 11:39 PM
Element's Avatar
My set of 3" duals from Lane is significantly lighter than JUST the section of the stock catback from where the pipe goes over the axle. Add in the weight of the cats and stock y-pipe, and it's porobably double the weight of the duals.
Old 01-07-2007, 01:13 PM
jimmypop13's Avatar
I just got Lanes true duals and they seem pretty heavy but I can tell the only reason why is because of the Flopro Twister mufflers. Jeez they weigh alot. I'm about to replace them though so after I do that, I bet it will be lighter or the same as my GMMG catback
Old 01-07-2007, 01:17 PM
SiL3NtXWS6's Avatar
515/500 motor
750/800 spray
You can go ahead and jump on the backpressure train hype, but i don't believe in it all that much. My car has neck snapping torque and power. I gained torque with this setup vs a single straight pipe/ Y pipe setup. Most of the fastest N/A LS1 guys are running either extensions or bullets off each header.
Old 01-08-2007, 09:08 AM
lsx24's Avatar
There is one thing I'm curious about, what about the scavenging effect of duals?
Doesn't that outweigh the lack of backpressure of open headers? You could argue the same reason not to run shorties and go with long tubes, because shorties don't scavenge...
For example, if you were to run open headers, let's say you're at 400 rwtq. But if you were to run true duals with xpipe crossover, you'd be higher, at 410 rwtq, for instance. Wouldn't running duals make the most power, not open headers?
You could make the argument that NHRA drag cars run open headers, not duals. But they are hardly lacking for hp, they can make whatever hp is legal with the parts required in their class, I don't think they need to run duals, for them the simpler the better.
Old 01-08-2007, 09:10 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
When you are making 500rwhp scavenging isnt going to be a factor like you would think.
Quick Reply: Duals vs SIngle C/B.... Weight and HP
