How to tell,ls6 from ls1, while installed?
Old 01-05-2007, 01:01 PM
senicalj4579's Avatar
Default How to tell,ls6 from ls1, while installed?
hey guys, how can i check to see if i already do not have an ls6 intake installed while its still installed? i'v seen pics of under the intake but obviously i cant tell if its installed. i see that one of the tubes in the front,where the tb bolts on to,may be different. is this a way i can tell?
Old 01-05-2007, 01:07 PM
brad8266's Avatar
Run a search here on the part number that is stamped on it, it is visible while installed.
Old 01-05-2007, 01:13 PM
bww3588's Avatar
look on the passenger side of the intake for the coolent lines. if one is running under the intake to the back of the engine you have an LS1. if its not and it only runs to the other side of the engine (passenger to driver) then you may have an LS6. if you have EGR you have an LS1. if not LS6. again like brad8266 said, run the part number to be sure.
Old 01-05-2007, 06:40 PM
thanks guys. i have 12560688 and it says i have the ls1. thanks for the help
Old 01-05-2007, 06:45 PM
brad8266's Avatar
Thats not 100% the best way to know. I have an LS6 intake yet i still retained my coolant lines. I grinded down the ridges on the bottom of the manifold to make the extra room needed. If you went by coolant lines you would think i have an LS1 intake, but i dont.
Old 01-05-2007, 06:46 PM
brad8266's Avatar
Old 01-05-2007, 06:51 PM
yeah i was thinking the same thing when you told me i should grind it down. i think i'm gonna save myself 50$ like you did and go that route.
Old 01-05-2007, 08:29 PM
are all the ls6 intakes the same? like the intake off the z06? and what do i do with the egr fitting?
Old 01-05-2007, 08:50 PM
brad8266's Avatar
Yeah they are all the same. I just pulled all the EGR stuuf out and deleted the EGR code out of the PCM.
