True duals w/magnaflow mufflers
Would a true dual system w/regular magnaflow mufflers and 2 bullets either before or after the mufflers pretty much have the same "tone" as a magnaflow catback, just be louder? If anyone has any clips, please do post them up.
I don't think you would need 2 bullets as well as 2 Regular Magnaflow mufflers unless your trying to quiet your car down alot. A setup with Just magnaflow mufflers would have a much better tone then the regular catback/ORY setup.
The tone will be different because it's True Duals, that will make the most difference. The fact that you are running Magnaflow mufflers is the next big thing that changes the tone. It will sound much more refined and deeper being True Duals.
The tone will be different on a catback, because a catback uses a ypipe. A ypipe system will always sound a little more raspy and tinny than a true dual system, no matter what mufflers. All true duals have a similar sound to them at the root of it, just slightly different tone depending on the muffler.
