Need Help(car Wont Start After Manifold)
Old 01-10-2007, 12:40 AM
T-REZ's Avatar
Default Need Help(car Wont Start After Manifold)
i put on the lingenfelter manifold,checked everything. went to start it up and bam.there is a pop and i see a small bit of fire or flame from pass side closest to firewall.what the hell could be wrong.please help,thanks
Old 01-10-2007, 12:50 AM
camm3d&slamm3d's Avatar
check your fuel lines...that could be the ticket...
Old 01-10-2007, 12:52 AM
T-REZ's Avatar
i will check right now
Old 01-10-2007, 01:01 AM
any luck?
Old 01-10-2007, 01:08 AM
T-REZ's Avatar
all lines seem ok.do the injectors need to be any one way
Old 01-10-2007, 01:09 AM
i dont know about injectors...but you say when you try and start it it sounds like its catching fire?
I would just make sure everything is back together and everything you took off/un-hooked is put back the same...
Old 01-10-2007, 01:18 AM
T-REZ's Avatar
its not catching fire,but i seen a spark or something fron that injector.i did remove the egr but i thought that would just throw a code.
Old 01-10-2007, 01:30 AM
T-REZ's Avatar
any other thoughts please
Old 01-10-2007, 02:55 AM
MjMaro's Avatar
make sure ur injectors are in all the way, lube the 0-rings with wd-40 so you won't tear em when you push them in -- are u throwing any codes?
Old 01-10-2007, 09:01 AM
Weezzer's Avatar
Did you have a set of like 8 bolts or studs left over from the install package?
There have been other threads about how if the stock bolts/studs are used for the reinstall - that the lip or head spacing of the stock bolt sticks out approx. 1/16" too far and won't allow the intake manifold to seat correctly. This also tends to crack the bottom of the intake manifold when its torqued down.
I'm not sure if this info is related to your type of intake or if it is only related to another manufacturer's intake. I just recall seeing this problem from time to time. You will have to do further research to determine if this could possibly be one of the causational factors to your dilema.
Old 01-12-2007, 03:00 PM
T-REZ's Avatar
ok thanks for the help.i will be going over everything today
