TB spacer
Old 01-10-2007, 11:31 AM
FU_I_AM_UltraZ's Avatar
Default TB spacer
Which is a better spacer from your expeariences... the Motorvation or Helix? can't decide.
Thanks
-Charlie
Old 01-10-2007, 11:35 AM
Kleeborp the Moderator™
MeentSS02's Avatar
I'll say it before someone else does...save your money.
Old 01-10-2007, 05:19 PM
well.. i was going to upgrade to a ported tb and thought... i gained 5 rwhp on my carb. 383 stroker, why not try it on my ls1 camaro
Old 01-10-2007, 06:46 PM
staringback05's Avatar
port your tb yourself, save your money....
Old 01-10-2007, 07:07 PM
black00ssFL's Avatar
spacers don't work on a fuel injected setup. The idea behind a spacer is allow more time for atomization and/or help mix air and fuel better. Like you said, works well on carb setups and throttle body injection setups where fuel and air come into the intake at the same spot. But since fuel enters through the injectors right before the cylinder head, it's absolutely usless on a fuel injected setup. Like said....save your money.
Old 01-10-2007, 07:08 PM
LS69TA's Avatar
You want the air flowing as straight and smooth as possible.
Old 01-11-2007, 10:01 AM
okay.. thanks black00ssfl
