Intake Swap Questions!!
Old 01-11-2007, 01:02 AM
4yall2nv's Avatar
Question Intake Swap Questions!!
well ill get straight to the point, i have a 2000 trans am(ls1 intake), and my cousin has a 2002 ws6, he said i could have his intake(ls6 intake) and i would give him mine, he isnt into racing like me!! so i was wondering if i could just swap them or is there anything that i need to know before attempting this! will everything line up will the tbs fit right,well TIA for all the feedback!!
Old 01-11-2007, 01:34 AM
mvvette97's Avatar
everything will bolt up fine. You will have to take a grinder and grind the ridges down on the bottom of the intake. If you don't the intake will hit the steel coolant lines that set below the intake
Old 01-11-2007, 03:12 AM
SweeTbone's Avatar
Or you could get the +01 coolant pipe and plugs for the rear. Here are the install instructions, I used them and everything went fine. http://www.ls1howto.com/index.php?article=5 I'd also pick up a oil pressure sending unit as well. I picked up one when I installed my LS6 intake. I didn't break the stock one, but it's nice to have it as a back up so you are not running to the auto parts store mid-project. I hate that.
Old 01-11-2007, 03:31 AM
RrCoX22's Avatar
another major issue your gonna run into is the EGR valve... as you will need to delete the module, block off your passenger exhaust manifold provision and tune out the code
Old 01-11-2007, 12:11 PM
4yall2nv's Avatar
thanks guys!! anything else i need 2 know, doesnt sound like much. oh and the egr valve had already been deleted, so putting the ls1 intake on the 02 wont be a problem right?
Old 01-11-2007, 12:20 PM
Sh4Dy's Avatar
Should be fine.
Old 01-11-2007, 07:49 PM
cabech984's Avatar
does anybody know where I can get a few pics of the intake and where it needs to be grinded? Or is it something that will be self explanatory once I pull the stock intake off? Thanks!
Old 01-11-2007, 09:36 PM
cabech984's Avatar
Anybody at all???
Old 01-11-2007, 09:38 PM
Tainted's Avatar
you'll see where when you go to grind them down
Old 01-11-2007, 10:17 PM
SweeTbone's Avatar
If you're determined to use the stock coolant line, I would take off the LS1 coolant line, then you can place it on the LS6 intake as a template and only grind down the ribs that need ground down. Throw the line back on and install the intake.
Old 01-11-2007, 10:24 PM
cabech984's Avatar
I wouldn't say determined, I'd say cheap, lol. The stock stuff works fine for me and if I can keep it w/o damaging the LS6 intake then thats what I'll do!! Taking it off though is a good idea, thank you!!!
Old 01-11-2007, 10:51 PM
matt94z's Avatar
why don't you swap coolant lines as well? He's not going to need them with the LS1 intake.
Old 01-11-2007, 11:04 PM
cabech984's Avatar
yeah, He should just swap them too. I thought you were talking to me, lol!!
Old 01-12-2007, 12:12 AM
4yall2nv's Avatar
thanks guys, looks like i got a project this weekend!! oh and cabech, take some pics so i can see them so i know what 2 grind down 2!!lol
Old 01-12-2007, 01:17 AM
J's99Zrated's Avatar
I wish someone would swap an LS6 intake for my LS1. Hint, hint.
Old 01-12-2007, 11:09 AM
cabech984's Avatar
I will do!! Getting ready to start the swap right now!!
Old 01-12-2007, 03:32 PM
cabech984's Avatar
I had to test fit the intake three times before everything was right. The last time I just grinded down all the outer ridges and a few along the way. I didnt get to take a pic, I killed the camera battery taking pics of the intake off the car. Sry, just be careful when you grind not to cut through the flat parts of the intake.
It is really easy if you have a die grinder, some of the raspy looking bits and turn the Air Compressor pressure!! It worked for me. Now I just need to put the fuel rail back on and fire this pig up!!
Old 01-12-2007, 05:59 PM
b1er's Avatar
for future reference here's a pic of the areas that need grinding:
