TPIS 90mm TB and Valve cover Breather line
I have the TPIS 90mm TB and while hooking it up I noticed it had no vacumn nipple for the breather hose coming off of the Passenger side vavle cover. Do people usually put a plug over the valve cover nipple?
I still haven't figured out what I'm going to do about the valve cover breather since there is no provisions for a vacuum hose on the throttle body.
I do have a catch can but that is something separate for the PCV system.
Unfortunately I have bigger problems now. It seems that the TCS servo is acting up again and I'm only getting 20% pull from my throttle cable. Worse than I had with my stock TB (75% at the TPS). The cam on the TPIS is smaller, I'm going to see if I can swap cams over, but it would be nice to know what the real deal is with the TCS servo and Throttle cables in my car.
That's what she said...
You can throw on a non-TCS throttle cable for a quick-fix if you've got a dyno appointment.
As for the PCV, as long as that line connects upstream of the throttle body blade, it will work the same. You can even attatch it to a small filter (it pulls air into the crank case, so you've got to filter the air into it). We normally refer to it as the "Fresh Air Tube".
