What type of vibration is associated with poly motor mounts?
No vibrations here either. Like orange said, the cam lope is really felt in the whole car, but in a good way. Poly mounts really tighten up the car. I can't say the same when I added a poly transmission mount though. I couldn't stand the buzzing and vibrating and put the stock mount back in.
Vibration with my poly tranny mount was so bad I took it out and went back to stock a week later. A couple years later I went to poly engine mounts (my original stockers were completely shot - engine could move at least an inch) - I was worried about vibration but there was no problem. Vibration was actually better than with the shot stockers.
Installing them is a different story. I put them in with my LT's in place and I would never want to do that again. If anyone is installing headers - do the motor mounts at the same time.
Steve
Steve
That's what she said...
Steve
Steve
Originally Posted by Rob Hood
Is that the only reason people change the motor mounts, since they're installing headers at the same time? Are they prone to failure at XXXXX mileage?
Originally Posted by Marc '99T/A
How bad would it be to do while doing a H/C swap?
With the heads out of the way, you MIGHT be able to get to them easy with the headers pushed over, but I doub't it. At that point, you may as well pull the headers.
My poly engine mounts went in with my cam. It's a very mild, low shake for me. Not bad at all, I actually like it because my cam is so mild there is very little lope. It also fixed my y-pipe banging on the floorboard and my clutch chatter.
Like it's been said above, it's hell to install them. I actually paid a shop big bucks to have it done just so I wouldn't have to worry about it.
I felt just a slight increase in cabin vibration. On both my performance cars I've had poly motor mounts, and recommend them. They really tighten up the structure, and don't cause any harsh vibrations. Same goes for the poly trans mount, I thought it was well within the definition of daily driver.
yea im about to order my poly motor, trans, and torque arm mounts, and im curious as is the vibration that bad with the trans one? i have an a4, also how the difference between the stock and poly torque arm one?
Steve
