O2 sensors
Old 01-15-2007, 11:06 PM
LS1Z28_98's Avatar
Default O2 sensors
OK, I tried searching for this to no avail. Seems like everybody had good luck. I put new headers on some time ago. I used the Bosch downstream O2's for a Corvette as my upstream ones. Well, I'm going on my 3rd set in a year. They are not failing in years or months, but in WEEKS. Is there another good O2 out there to use or am I doing somethng wrong or what. I can watch my fuel gauge go down when the O2's fail. Not to mention whats happening to the internals from such a rich mixture. Is this something anybody can suggest?
Old 01-15-2007, 11:15 PM
Da Swami's Avatar
When they go do they throw the usual o2 sensor codes?
Or is it like a "silent" fail where you just know they're malfunctioning but there's no SES?
Old 01-15-2007, 11:41 PM
That's what she said...
TheBlurLS1's Avatar
That's strange!
I don't think anything's going to work better than the 13111's, you may have problems elsewhere. Can you get us the exact codes it was throwing?
Old 01-16-2007, 12:07 AM
Twinki025's Avatar
I had the same problem. Are you using extensions? Is it throwing up insufficient switches? Let me know? My problem was the extensions were bad.
Old 01-16-2007, 03:18 AM
LS1Z28_98's Avatar
I'm not using any extensions, and it is throwing codes. Its 2 codes per sensor, 4 in all. I believe one was that it was switching too slowly. Lemme hook up the little do-hick-ie and I'll get exact codes.
Old 01-16-2007, 10:31 AM
taintedmeat's Avatar
Probably need a tune.
