Where to grind fins on ls6 manifold
Old 01-18-2007, 05:39 PM
MjMaro's Avatar
Default Where to grind fins on ls6 manifold
I'm getting ready to do the swap and im wondering where i need to grind the fins on the manifold so itll fit over the ls1 coolant lines, anyone with a pic please post it, i know there is a pic out there and after searching for an hour couldn't locate it, thanks
Old 01-18-2007, 06:14 PM
Tainted's Avatar
youll know where to do it when you go to seat the manifold
Old 01-18-2007, 07:48 PM
dpw41285's Avatar
cant do that on the metal intakes
Old 01-18-2007, 09:06 PM
MjMaro's Avatar
Trying to get it done ahead of time, less of a headache. I KNOW there is a picture of it on tech but I can't find it.
Huh? I havent said anything about a metal intake
Old 01-18-2007, 10:50 PM
W105's Avatar
Should help ya out!
Old 01-18-2007, 10:52 PM
Tainted's Avatar
isnt it better to keep the ls1 coolant tubes anyhow?
Old 01-18-2007, 11:23 PM
That's what she said...
TheBlurLS1's Avatar
It's debatable, but it's definatly not WORSE. Will it make a difference for most people? Probably not.
Supossedly, the road racing guys claim it vents the air from the rear cylinders faster and helps prolong the life of the #7 hole.
Old 01-19-2007, 09:08 AM
MjMaro's Avatar
Originally Posted by W105
Should help ya out!
Thank you sweet jesus
Old 01-19-2007, 09:12 AM
brad8266's Avatar
yeah thats exactly how I did mine. Good pics!!
Old 01-19-2007, 09:42 AM
MjMaro's Avatar
When you put it on the car should you have the foam pieces in there or will they cause clearance issues with the coolant lines?
Old 01-19-2007, 09:43 AM
Tainted's Avatar
Whenever I get my ls6 intake i was plan on using the sl1 tubes just so I aint gotta buy the sl6 ****. but now with an explanation about it Im gonna do it for sure now, if there anything I can do to prlong its life then I'll do it
Old 01-19-2007, 09:48 AM
joecar's Avatar
Could put two of the front LS6 tubes (one in front, one in back, a hose from each into a Y, and then onto radiator).
Old 01-19-2007, 10:17 AM
Y2K Z28's Avatar
Why? It's easier to just grind.
Old 01-19-2007, 01:17 PM
99kamarokid's Avatar
im getting my intake soon to, and was wondering if those foam pieces that u took off to grinf the intake..can u just stick them back on, or do u not replace them?
Old 01-20-2007, 06:01 PM
mvvette97's Avatar
I'm wondering the same thing.
Old 01-21-2007, 11:27 PM
MjMaro's Avatar
anyone have anymore input on the foam pieces??
Are coolant plugs neccesary if ur keeping the ls1 coolant lines when swapping to the ls6 manifold?
Old 01-24-2007, 06:53 PM
anyone on the foam pieces??
Old 01-24-2007, 07:05 PM
2000TransAmWS6's Avatar
maybe someone could help me understand what the point is in grinding those fins... when i put my LS6 intake manifold on there was a metal tune in the front under the TB that had a rubber hose coming off of it, and on the back of the block there were 2 plugs. the small black tubes under the manifold i just left as is. i didn't have any kind of fitment issues or anything.
so, how come you grind the fins?
Old 01-24-2007, 07:26 PM
Hell'sChariot's Avatar
I dont see why you need the foam, leave it off. My new intake didnt come with the foam, so I wont have any.
Old 01-24-2007, 07:27 PM
TheBlurLS1's Avatar
Sounds like someone already put an LS6 on your car. Black tubes under the manifold? You probably mean the wires for the knock sensors.
My FAST doesn't have the foam pieces, I say chunk 'em.
Quick Reply: Where to grind fins on ls6 manifold
