Installed headers is it normal to create a lot of smoke?
Like the title says. Started the car with open headers and when you give it a lil gas a ton of gray/black smoke comes out. Kinda hard to tell what color at night
Originally Posted by ErikElvis
Im hoping its normal. I have to check the plug wires again though. Its hard to get some of these MSD's to click
If its still smoking after you have driven it for a while, then you might have an issue with something else.
Thanks guys. I let it sit for a bit and restarted it and it seems the smoke died down. If I didnt get out of that garage it would have seemed like I commited suicide with all those fumes. They did give me a instant headache...
Mine did the exact same thing. A little smoke at first is normal. Give it a little time and the smoke should go away. Mine went away after just a mile or so. If it doesn't go away you may want to make sure you don't have other problems.
Originally Posted by FU_I_AM_UltraZ
you'll get fumes for sure and if they are coated... the coating has a break-in smoke until every settles in. and for the future... if you install hi flow cats, they will smoke and have a burning brake smell to them.
