Well...?
Well...?
Got my car running recently and I was too use to my LT1, this is a whole nother ball game.
What do you guys think I'm making rwhp wise? All I know is I'm running enough that my 275/40-17's aren't hooking worth a ****. I was thinking ~325...
Mods in sig...
What tires do you recommend, i was thinking the same size as above MT DR's
I'm thinking about getting Firehawk wheels which would put me around ~330rwhp..
Mods in sig...
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Question: Why didn't you put a cam in when you had to change the oil pump or the chain? The only power adders I see are the Intake, TB, cutout, ASP underdrive pulley, and the not so powerful mac mid-lengths. If you ask me it is more like 300-310. I have dynoed about 600 f-bodies over the last 2 years and 98's were also down on power from the get go compared to 99-02.
Not trying to be a dick, just being honest.
If you want real power, finish out the rest of the bolt-ons, and go with a new set of heads and a cam to match. Then you are looking at 380-390 or possibly 400+ depending on combo.
I'll break it down:
I had a '98 T/A dyno 311 with borla and free mods (free ram air, TB bypass, EGR mod). You've got a cutout plus macs so I'll give you at least 5 more over the stock manifolds and borla plus the LS6 manifold for at least another 5, ported TB for about 3 (being conservative) and UD pulley for about 5. That's about 18 more than my 311 for a total of 329 You didn't mention having a lid or not. If you do then that's another solid 5 for around 330-335. Some things to consider are that not all dynos are the same. That being said I still stand behind my 330-335 prediction. Good luck and let us know.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Red99TA
I'll break it down:
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by slow trap
that is true but this guy has an a4 and a 8.8 with 3.73 cogs also. even locked the a4 will be down a few horses to the m6,correct ? i'll say 320-325 rw.
Seriously. This guy already has a suspension that will probably land him a good ET. Who really cares about numbers anyway?
Originally Posted by orangeapeel
What? Since when do you get more power with wheels?
I live in CA and this state is full of many fartards when it comes to smog. I put this car back together stock and I'm very lucky that my county does not do the two year smog BS.
So what I did was everything that I could do the strengthen the motor and make it pretty, but still pass smog.
Now when I do my heads/cam AFTER my one and only smog i will only have to do lifters and pushrods. May be stupid but that was my reasoning. It's a second car so a little garage time is just fine. Since I did everything myself I know I can do it again.
The wheel thing was a joke obviously...
btw I plan on doing the stage 1 or 2 LS6 heads and MS4
I'll break it down:
Yeah, 330 is pretty high for an a4 with few bolt ons...It can be done. But it is high.
Then again I'm use to a nearly stock LT1.
I didn't even notice the 8.8 and yes that combined with the auto will rob some power vs. an M6 w/ a 10 bolt. The reason one guy said 98's were down on power is b/c of the heads they came with. New prediction: 325
Thank for the info!
